help! i'm burning up!
Old Jul 9, 2003 | 09:42 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
i know third gens are hot cars, but the heat just seems to pour through my firewall! has anyone out there used this aluminised mat material to insulate the interior? do you put it on the floorboard or on the firewall inside the engine compartment? i have an '83 w/305 and stock exhaust manifolds. i haven't noticed this much heat in the past...but this summer it's been 95 almost everyday! thanks
Old Jul 9, 2003 | 09:53 AM
Odyssey's Avatar
Wah wah wah.... It's 115 here in Las Vegas and I have no AC. You'll live! lol
Old Jul 9, 2003 | 12:21 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
What temp is your engine running at?
Old Jul 9, 2003 | 04:45 PM
wdigitog's Avatar
nothing wrong with the car....it's just hot. have any of you out there used heat shieilding material? the engine runs consistently at 200....got a 160 thermostat.
Old Jul 9, 2003 | 08:28 PM
Odyssey's Avatar
Mine runs around 180-190 with the fans constanly on.
Old Jul 10, 2003 | 07:02 AM
wdigitog's Avatar
that's fine....but i'm interested in interior heat! firewall heat...heat that comes in and fries my feet! do i put heat proofing under the carpet, or inside the engine compartement (on the firewall)?
Old Jul 10, 2003 | 08:35 PM
roxieshotrod's Avatar
Car: '91 RS
Engine: 383
Transmission: Turbo 350
i did dynamat extreme on the interior - just pull the seats, lift the carpet (i didnt even take the center console out) go as far up as you can, and back to the front edge of the seat - made a HUGE difference in heat down there.. I intend to pull the whole interior this winter and do the whole car.. but thats more for noise than anything else. It was well worth the small amount of time it took.. I say do it!
Old Jul 10, 2003 | 10:58 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
yeah, my GTA is nick named the sauna cuz it gets so hot around the feet...engine usually cruises around 220F, so its not too hot. how much was that dynomat? how much did you get?
anyone know if b-quiet can heat shield as good?
Old Jul 11, 2003 | 06:39 AM
wdigitog's Avatar
thanks for the info! that's what i wanted to know. i'm planning to restore the a/c on my car, but it's not worth doing it if the damm heat keeps pouring in! i'll get the dynomat stuff!
Old Jul 11, 2003 | 08:21 AM
82camaro's Avatar
Car: 82 camaro SC
That year of camaro doesn't have a valve on the heater core so the heater core gets hot water all the time. It will heat up the surrounding vents and your feet. Plus, the 'doors' in the dash that control the vent/heat/defrost etc... probably don't seal as well as they used to and may be allowing vented air to pass through the hot heater core. You might consider a manual valve for the heater core. Later third-gens had a diverter valve that stopped flow though the heater core when the heat was off.
Old Jul 11, 2003 | 04:21 PM
Car: '91 RS
Engine: 383
i bought the 'bulk pack' (36 sq ft) on ebay (i did the hatch also) for about $100 shipped, but you only need maybe 4 or 5 sheets (each sheet is 18" x 32") if you do both driver and passenger.. you can also get wedge packs if you dont need so much. I think those are about $30 or so.. It may take two of them to get it done well. If you do go with the bulk pack, just cut it up with a utility knife, its much easier to work with in smaller pieces! And remember, I used the Xtreme dynamat, not the regular dynamat! Good luck!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
