door vent
Old Jul 23, 2003 | 12:34 AM
FU-Q's Avatar
door vent
you know what im talking about? the one when you open the door. what is it for? ventlation? and whats the best way to deaden the vibration when bumpin the speakers?
Old May 24, 2009 | 10:11 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: door vent
I know this post is 6 years old, but no one answered it and I was tryin to find the answer on google and found this thread. So I'm gonna ask th same question, what are those door vents for?
Old May 24, 2009 | 10:26 AM
87350IROC's Avatar
Car: 87' IROC
Re: door vent
I'm not exactly sure what the vents are for. Some people will say its to ventilate the climate control system.
To deaden the vibration I used some foam tape where its touches the body. Worked well and looks untouched.
Old May 24, 2009 | 10:37 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: door vent
They're apart of the ventilation system called the body lock pillar exhaust valve (check your owners manual for more info).
JamesC
Old May 24, 2009 | 10:45 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: door vent
it is to provide air flow through the body so that gases do not build up in them.
Old May 24, 2009 | 01:10 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: door vent
Yes, they are for ventilation.
They also let air escape quickly when you close the doors with the windows up.
Old Jun 1, 2009 | 11:51 AM
ttoplover's Avatar
Car: 1989 Trans Am
Engine: 305 tpi
Re: door vent
GM first introduced these vents so to speak in around 1970 (correct me if I am wrong on the year) as part of their flow through ventilation system on all GM cars,,,,
Old Mar 3, 2010 | 05:04 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: door vent
thats odd, iv always thought they were for heating the door to they didnt freeze shut when you had the car started ( i know that seems like a retarded idea but i didnt know of anything else)
Old Mar 3, 2010 | 05:07 PM
jj74sd455's Avatar
Car: 91 bird
Engine: 305 tbi
Transmission: 4 speed automatic
Axle/Gears: factory
Re: door vent
if you used some 3m adhesive that should take care of it
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
