I would like to....
Old Jul 23, 2003 | 10:44 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I would like to....
Get rid of that stupid beeping when I have the keys in the car and the door open. I am not worried about locking the keys in the car and I dont want to always have the key in the on position. Is there any way to disable it? A fuse that I can take out, a wire I can disconnect?
Brian
Old Jul 23, 2003 | 02:53 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Normally, you can just pull out a little on the key and it will stop beeping....
Old Jul 23, 2003 | 03:59 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Yeah, just jiggling it works for me...
Old Jul 23, 2003 | 04:38 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I think I didnt state what I want clearly. I want to have the key in the #1 spot. Where you turn the key and the radio comes on but all the dash crap doesnt come on and the fans stay off. I want to have the key there and have the door open.
Brian
Old Jul 23, 2003 | 05:33 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Unplug the buzzer.
Old Jul 23, 2003 | 05:45 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Originally posted by Zepher
Unplug the buzzer.
Where is it?
Old Jul 23, 2003 | 06:56 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
its up under the dash...atleast it should be (thats where mine was) its a black box probably as long as your hand
Old Jul 24, 2003 | 10:10 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
pull the wheel, and lock plate, and there is a little metel clip thing on the key cylinder, take it out and no more buzzer, but the headlight buzzer will still work
Old Jul 26, 2003 | 11:36 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Call me crazy, but don't you just rotate the key to the rear position (accessory) and the radio will function without all of the console and fans turning on? This works, why unplug the buzzer?
Old Jul 26, 2003 | 11:59 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
with the door open, it will still buzz in the acc position.
Old Jul 27, 2003 | 11:00 AM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
Put tape over the door switch?
Roll the windows down?
I just pull on my key a little and the cylinder pops out a small distance and it stops buzzing. Maybe its loose, I don't know if they are all like that
Mazz5280
May 4, 2014 03:28 PM
58mark
South Central Region
Jul 11, 2011 07:07 PM
Camaro305SB
Mar 2, 2011 12:38 PM
