hatch pulldown - missing wire
Old Jul 24, 2003 | 01:29 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Ok i have the hatch pull down assembly. I was able to refurbish the motor and fix the gear my self with my excelent techniques. But the thing only goes down. And when i try to shut it the thing went down to low. so i couldn't shut it. I have tried for hours to get it to shut and go up but nothing. Now i have this wire shown here that connects to nothing
and
Its a white wire with a small black connector and its the only one with that connector and nothing to connect it to. you can see that blue wire with that big white connector. It connects to something but the white one has nothing. What wire color does it connect to? what wire do i have to tap into to connect it? I do not know if the car came with this stuff stock but it is an 86 so it had to right? It was also previously taken apart and the d00d ruined one of the motor brushes and i had to put in a new one and they broke the gear in half. I super glued it back together then put some epoxy on it. I think it will hold.
Old Jul 24, 2003 | 04:09 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
The white wire connects to another wire (black with an orange stripe) which then goes to the small light in the cargo area. It 'grounds out' when the hatch is unlatched to light up the bulb.
Pete
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Apr 30, 2019 12:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
stalkier
Aug 13, 2015 12:59 PM
