adding hatch release the hard way
Old Aug 5, 2003 | 07:48 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
I've read many articles on how to do this, but ll have been lacking one thing. Pictures. Does anyone have any before and after pics? I yanked a "fuel filler door release" solenoid from my dad's car (Ford Tempo) because it has been missing pieces since 5 years ago. The pulling part works fine. I just need some pics to see if I can make it work, or if I should just get a GM solenoid.
I've seen a gm solenoid and the differences as far as I can tell are the mounts and the pull cable thing is a little longer. I was thinking of mounting it anywhere within reach of the existing mechanism, and tying the solenoid pull cable onto the same pull cable that I assume connects to the key cylinder. Then I could sue botht he key and the electric release
Old Aug 5, 2003 | 09:57 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
If you have the old manual hatch then all you have to add is the silenoid. Along with its wiring harness.
Old Aug 6, 2003 | 12:50 PM
MechCD's Avatar
Engine: LO3, Vulcan
I'm trying to cheap and use a non GM solenoid
I think the wiring is there, there is a relay spot under the dash
punkmaster98
Sep 30, 2015 11:01 AM
Breazlan
Sep 25, 2015 11:20 AM
scottmoyer
Sep 7, 2015 07:06 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
TBRays98
Sep 6, 2015 05:05 PM
