Aftermarket T-Tops
Old Aug 22, 2003 | 09:30 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Aftermarket T-Tops
Any of you guys know of a place which sells an "aftermarket t-top kit" for our cars which contains everythign you need to do this?
Thanks,
dave
Old Aug 22, 2003 | 10:40 AM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
Do you mean a kit to convert a hardtop to t-tops?
Old Aug 22, 2003 | 10:46 AM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
The conversion would cost more than it would to buy a T-top car. You'd have to cut the roof off your car, then weld a T-top car roof to it. Just make it a Targa Top if you wanna spend that much money.
Old Aug 22, 2003 | 12:17 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Yes a kit to covert a Hardtop to a t-top.
A couple of places back in the 80's/90's use to sell kits which contain all the parts you require so you find a body/custom shop which can/is able to do it. I am not saying that i am going to be doing something like this...I am just curious as to if these sorts of "kits" are still around as they use to be.
Old Aug 22, 2003 | 10:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The same places most likely went out of business at the same time too.
C & C was the company that did the tops for GM and went belly up before the end of the 3rdgen production (because their tops sucked). At least if I am remembering correctly...
Old Aug 22, 2003 | 10:33 PM
FruityOne's Avatar
No, C&C did offer a conversion but it wasn't supported by the factory. Also, the C&C T-Tops aren't that bad. They do have a nice, deep water channel, but if your weather stripping was worn then they like to leak where the side window meets the edge of the T-top and roofline. Easily fixed with some silicone.
Factory T-tops were done by ASC.
Old Aug 22, 2003 | 11:12 PM
deadbird's Avatar
Engine: TPI 305/ v6
Thanks for correcting that for me
I've also owned a C&C topped car, they suck.
Old Sep 6, 2003 | 06:09 PM
echo5blud's Avatar
Car: 1986 Z28
Engine: 305...350/383 in progress
Transmission: 700r4...fresh rebuild
I have been thinking about this one for a while now. One of those things that is way down the line though. I would like to have t-tops, but the only car I have found with T-Tops the battery exploded started a fire and the poor ole' boy couldn't get the hood open to get the fire put out. Anyway, is this a reasonable idea, I heard one guy say that it would be cheaper to just get a car with t-tops. Let me know what you guys think.
Old Sep 10, 2003 | 03:10 AM
305 91camaroRS's Avatar
i wouldnt do it...i would just buy a car that came with ttops thats just my opinion
:hail: t-tops they rule
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
