decklids
Old Sep 6, 2003 | 08:09 PM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
decklids
Is there a part number or something I can get to order a new decklid? Mine is just about gone, and I don't really want to get a whole new hatch just for one metal piece. Also, is "decklid" the proper name for the metal part of the hatch? I just can't find any sources for these things.
Old Sep 7, 2003 | 09:33 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
what do you mean yours is just about gone? i dont know of the part number and you probably cannot get it anywhere but a bone yard, i changed my deck lid only and it was a pain, go to the junk yard and find a decent one and change out the whole think, also i dont think it is metal either
Old Sep 7, 2003 | 09:49 AM
MechCD's Avatar
Engine: LO3, Vulcan
It looks like water got in throught the spoiler mounting holes. It just sat inside the metal part of the lid and rusted away. The plastic part on the inside is fine, as is the spoiler (both plastic).
I will try looking in a junkyard, but the locals have been telling me that most of the junkyard ones will have suffered the same as mine.
Old Sep 7, 2003 | 07:32 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I had the same problem with my original one. I got a good one from the boneyard and had it painted with the rest of the car. When I reinstalled it I put sealant around all the bolt holes and ran a bead of clear silicone at the front of the spoiler. The damned thing is starting to rust already though!!
Old Sep 8, 2003 | 09:48 PM
transam84's Avatar
best place to find a deck lid is def the junk yard. these deck lids are metal, or at least they are on 82-84 models. I swapped one out a an 83 once for one that had the spoiler holes and it was pretty simple and easy. just don't tighten any of the bolts until after you close the rear hatch and then crawl in the hatch area from inside the car and tighten them at this point. this way you get the correct spacing from front to back and you know the hatch will latch. sounds not to fun but really wasn't to bad, just took a few minutes and I only did this once.
Uglybronco
South Central
Oct 25, 2015 09:22 AM
Zrated83
Jan 4, 2004 09:38 PM
Skatepunk60
Jan 5, 2003 12:30 PM
