Underhood matting material
Old Sep 22, 2003 | 08:10 AM
ator's Avatar
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
I have a 92 Firebird Formula. My question is how inportant is the matting material under the hood. The entire car is spotless except for this material and I would like to remove it. The only purpose I see for this is to protect the paint from excessive heat. But is it absolutly nesassary? Can I remove it without causing problems to my paint? Any help would be greatly appreciated.
Old Sep 22, 2003 | 08:36 AM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
I've heard of people who removed it and had no problems. I don't believe it is absolutely necessary.
PS - Welcome to the boards.
Old Sep 22, 2003 | 08:46 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's more for quieting engine noises than anything. Your paint will be fine.
Old Sep 22, 2003 | 08:53 AM
ator's Avatar
Thanks, I think I will remove it then.
Old Sep 22, 2003 | 01:38 PM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
I havn't had mine on for about 5 months. no problems
Old Sep 22, 2003 | 09:39 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I live in sunny, hot So. Cal. I've had it off for 2 years now with no problems. It's mostly there to muffle sound and to help the engine warm-up in cold weather. I think it looks a lot cleaner with it gone.
Old Sep 22, 2003 | 09:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
but if you were to replace it, who makes factory looking replacements?
i would use dynamat or equ, but i dont want a shiny metal surface, id prefer somthing black
Old Sep 23, 2003 | 10:35 AM
Car: 1989 Firebird
I've seen it in the Classic Industries catalogue.
Old Sep 23, 2003 | 03:43 PM
deadbird's Avatar
Engine: TPI 305/ v6
GM.. they are still available.
Old Sep 23, 2003 | 04:24 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
It is designed to aid in an engine fire. The round plastic tabs are designed to melt first then the insulator would fall over the engine in an attempt to die it out.
By the way Ator, awesome car!!!
Old Sep 23, 2003 | 04:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I purchased mine from GM, perhaps, two months ago. If I recall correctly, the price was $44.
JamesC
Old Sep 23, 2003 | 04:44 PM
ator's Avatar
Thanks, I get compliments all the time, can't say as I mind either. I've got a 67 Camaro RS/SS fully restored about 10 years ago and I still will get more compliments for the Firebird.
Old Sep 23, 2003 | 04:46 PM
deadbird's Avatar
Engine: TPI 305/ v6
It is designed to aid in an engine fire. .
It does it's job aiding quite well too
Old Sep 23, 2003 | 05:11 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Originally posted by JamesC
I purchased mine from GM, perhaps, two months ago. If I recall correct, the price was $44.
JamesC
cool..
next pay check i might get a new one. perahps get new coolent and windshiled washer bottles at teh same time.
MrPackstin
Oct 25, 2017 08:09 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
1992Z28!
Nov 19, 2015 07:33 AM
ULTM8Z
Oct 2, 2015 01:25 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
