Anyone know where to get t-top panel weatherstripping?
Old Oct 4, 2003 | 08:20 PM
86blkbird's Avatar
Car: 1988 Formula now a T/A
Engine: LB9
I recently bought a so called "complete" weatherstripping kit off Ebay. It is the revised GM replacement kit. The kit is missing the two weatherstrip pieces that mount/glue to the glass roof panels that seal against the door window glass when the door is closed. Does anyone know if these are available?, If they are what the GM part numbers are?
Old Oct 5, 2003 | 01:28 AM
Morley's Avatar
Do you mean the rubber strip that over hangs the side window or the actual weather strip on the T top rail?
Old Oct 5, 2003 | 04:50 PM
86blkbird's Avatar
Engine: LB9
Sorry about the slow reply I've been working on the car all day. I need the sponge rubber weatherstripping that mounts to the glass t-top panel rails, not the plastic (oem rubber) drip edges. I tried using the factory original style weatherstripping that came on the panels but they don't match up properly to the revised weatherstripping that is on the body of the car. I am assuming there are revised panel weathersripping that matches. Any help you can give will be greatly appreciated! Thanks!
Old Oct 5, 2003 | 05:28 PM
Morley's Avatar
I'll look at my weather strip kit and see what numbers are on the T top pieces. I don't know if it is the "revised" seal set or not though.
Old Oct 5, 2003 | 07:15 PM
CaysE's Avatar
10165496 is the number on both the left and right weatherstrip pieces on the new GM kit. I'm not sure what the original numbers are.
$750 L98
Feb 1, 2025 02:25 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
tattmann
Sep 27, 2015 05:20 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
