headlights go down when driving?
Old Oct 5, 2003 | 08:09 PM
grndmasnightmar
Guest
Posts: n/a
:hail: <-- hey look my headlight!! my passenger side headlight has hesitation before it goes up then the actuTOR spins after it is up for a few seconds i figure the gear is stripped but why does it go down every once in awhile when i drive. also if i put my car in neutral and rev the engine aS I FLIP THE SWITCH THE HEADLIGHTS WILL COME UP WITH NO PROBLEM? whats that about. do the flip up lights run on vacuum or only the electric motors? any answers to these questions would be appreciated.
Old Oct 5, 2003 | 08:12 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
no vacuum what so ever!
Maybe because of possible gear damage the light motors require more power to move the light. By reving the enging you get a bit more juice out of the altenator?
Just a guess!
Old Oct 6, 2003 | 02:14 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
The headlight gears most likely are not stripped. The common thing that happens is that the plastic bushings inside the gear deteriorate and crumble. This allows the gear to free-wheel on the actuator shaft and the headlights will act just as you have described.
Here's what you need to fix the problem:
http://www.top-downsolutions.com/pro...products_id=35
Ghettobird52
Jul 5, 2024 11:18 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
