RS to Z28 Speedo
Old Oct 20, 2003 | 08:55 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
RS to Z28 Speedo
My speedometer quit working sometime this weekend in my 91 RS. I was wondering what all would have to be changed to install the 145?? Z28 Speedo in my RS. Direct bolt??
If nothing else, does anyone have a really cheap working RS unit Or even an extra Z unit if its a direct plug/swap.
Old Oct 20, 2003 | 01:18 PM
Adam Jones's Avatar
I don't know if it's direct bolt for the 91 RS. You have an electrically driven speedometer, and it might need calibration! It was a direct bolt-in for my 85 IROC when I swapped my 85mph speedo for a 145mph one, but it's mechanically driven. Check out the archives here on the boards, or check the tech articles section! :P
-AJ
Old Oct 20, 2003 | 01:32 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it should be a direct swap.
**edited because i can't read**
Old Oct 21, 2003 | 06:45 AM
Dale's Avatar
Engine: 350 S-TPI
Ok, so no calibration needed. What about the tach, I did some searching and some said tach was screwy afterwards. Just swap my rs tach into my z cluster and install?
Old Oct 21, 2003 | 05:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i donno if its a direct swap, but i DO know that they use the exact same VSS...
GTAman
Jul 3, 2024 07:29 PM
topteam54
Oct 6, 2015 12:21 AM
89newfun
Sep 16, 2015 09:28 AM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
