Shifter
Old Oct 22, 2003 | 04:53 PM
firebirdtank's Avatar
Car: 1985 firebird
Engine: V-8 305
Transmission: TH 700-R4
Shifter
could somebod please tell me how do i remove the shifter from a 1985 Firebird with automatic transmission. its the shifter with the button on the left hand side of the Handle???
Old Oct 22, 2003 | 04:57 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
on the front side of the **** there is a small staple like clip just shove a screwdriver in and pull it straight out i can make a diagram if you need but it's fairly simple once you do it
Old Oct 22, 2003 | 07:21 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
It's one of the hardest things to remove!!! What I did was... put on the emergency brake and put the car into drive (so you have room to get at the front of the shifter). Use a tiny screwdriver and I used needle-nose plyers to grab the tiny piece of metal (which does resemble a staple). Pull for dear life!
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
