got ghost flames? how to do?>
Old Nov 3, 2003 | 05:36 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
so i have seen ghost flames how is it done any idea? looks real sweet though i know that much.
Old Nov 4, 2003 | 11:52 AM
Pontiaddict's Avatar
It's basically the same as with normal flames, except you use either a clear with metallic or pearl, a thinned out candy color, or a slightly different shade of paint, depending on the effect you want. You usually only paint the edges of the flames as well, since subtlety is the key.
Old Nov 6, 2003 | 09:57 PM
91eagle's Avatar
Car: 2004 Dodge Stratus Coupe R/T
Engine: 3.0 V6
Hey could we get some pics. I have been wanting to do this and I want to get some ideas.
Thanks.
Old Nov 10, 2003 | 12:34 AM
bytal's Avatar
Car: 88 Pontiac GTA
Engine: 5.0L
Transmission: Manual
ya.. i dont exactly know what you guys are talking about here. but it sounds pretty cool. i wanna see what these things look like
Old Nov 10, 2003 | 07:34 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I had my car repainted this summer with ghost flames. The flames were put on after the paint but before the clear coat was sprayed. My friend who did the paint masked the flames off by hand using thin tape, I think some people use some sort of patter to do it. Silver Pearl was added to the regular color for the flames with more pearl towards the tips of the flames and fading into the factory color once you get closer to the front of the car. Then he added a color called Purple Haze to the tips of the flames to make them stand out a little more. It also gives the tips of the flames a slight purple tint in bright sunlight. These pics really don't show how good it looks in person but it will give you some idea of how it looks.
Old Nov 10, 2003 | 07:36 AM
jbenge's Avatar
a hood pic
Old Nov 10, 2003 | 07:44 AM
jbenge's Avatar
I need to do something about the ride height but not sure what to do yet. I'm going to attempt true dual exhaust first then see how much ground clearance I have after that before I lower it any.
Old Nov 10, 2003 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the idea with ghost flames is that unless you look carefully at the car, you dont see them....
its a neat lil custom trick that someone can do witout having a car that screams out "LOOK AT ME!"
Old Nov 10, 2003 | 07:07 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Don't know exactly how it's done, but sure does look good.
Old Jan 17, 2004 | 08:40 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Here are mine. They are white pearl with gold pearl tips. He layered it on pretty good so they stand out more, but at some angles you can't see them at all.
Here's a pic where they are almost invisible-
Old Jan 19, 2004 | 12:10 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
damn they look good
Old Jan 19, 2004 | 01:46 AM
Pearl Jammzz's Avatar
Car: 89' RS
Engine: 2.8 V6
I have thought about doin sum ghost pinstripes. Anyone have a pic of that? I have seen tonz of flame pix but none of anything else (in ghost form)
Old Jan 19, 2004 | 02:40 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
ghost flames are awesome, but i've seen some that jsut doesnt look right at all,
db057
Apr 28, 2019 07:45 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
