A/C delete ?'s
Old Nov 15, 2003 | 10:04 PM
Need4Speed1387's Avatar
Car: '86 IROC
Engine: 305 LG4 awaiting the crate Vortec 350
A/C delete ?'s
So when i got my car i noticed the ac compressor is gone along with all the hoses. i don't mind not having air conditioning, so i removed the ac core (i guess you would call it). how can i get rid of the big space that it takes up right now? i know i could prolly just throw some sheetmetal over it, but there has to be a different model that came on non-ac cars right? and is there anything else i need to do when deleting my a/c? thanks!!
Old Nov 16, 2003 | 07:35 AM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
https://www.thirdgen.org/techbb2/sea...der=descending Here ya go, try doing a search for things. Most likely they have been discussed before.
Old Nov 16, 2003 | 02:42 PM
MdFormula350's Avatar
http://members.***.net/iroczdave1/IR...rts%20Page.htm
Old Nov 16, 2003 | 02:48 PM
onebinky's Avatar
I chopped off the big part that sticks out, cut sheetmetal to fit over the opening, fiberglassed it in place, and then sprayed the whole thing with rubber undercoating. Works great so far, I just need to reinstall the resistors for the blower motor so I have more settings than high
Here's a pic
Matt
Old Apr 17, 2004 | 05:17 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
What does that part in the middle do, not the blower motor.
I have a sheetmetal A/C delete box with just a spot for the motor.
Old Apr 17, 2004 | 01:35 PM
onebinky's Avatar
I believe that's the resistors for the blower motor. They regulate the voltage that the motor sees, so you get your low and medium settings. High is controlled by it's own circuit.
Old Apr 17, 2004 | 04:14 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
here is what i did. i took a piece of sheetmetal and riveted into place. i still need to do the hole for the blower motor but the ac compressor area is filled. i am ditching the heater and ac. i am planning on buying one of those under dash heating units so i can defrost the windows but thats it.
Attached Thumbnails A/C delete ?'s-ac-delete-528-x
Old Apr 17, 2004 | 06:55 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
my plans eggzactly...
Old Apr 17, 2004 | 10:59 PM
onebinky's Avatar
A little off topic, but how do you like the holley digital module? I have one sitting on the floor behind me, and hopefully will get around to installing it tomorrow. Has it been pretty reliable? I picked up the digital module and lazershot pro coil brand new for $100 shipped
Looks like a very high quality piece, weighs about 5 lbs too
Old Apr 18, 2004 | 07:34 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
i did a little reading about it and it is very comparible to others so i figured why not. i got it new for 100 from jegs when they where being clearanced out. i havent tried it yet as the car isnt running. i am getting closer to finishing the motor though.
Old May 27, 2004 | 02:48 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Can you cover the rectangular hole with sheetmetal and still install the blower motor and have heat (fabricating an enclosure that holds just eh blower motor and relocating the resistors)? Basically, is there a reason that the a/c delete box sticks out from the firewall where the A/C stuff used to be? It's tough to find an a/c delete box without massive rust and i figure it'd look better if it were just a bare firewall there anyway.
Old Jun 27, 2004 | 08:23 PM
ss85tadude's Avatar
Car: 85 Trans Am
Transmission: 700-R4
This is what I want to do also. It just seems alot easier and would look alot better.
Old Jun 28, 2004 | 04:50 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
After my last post, I took a better look at how the system works. If you want to keep your blower motor functional at all, you can't cover over that rectangular hole. That's the point where air from the blower motor enters the passenger cabin. So pretty much, you need both holes in the firewall (circular and rectangular) to have any functionality If you're really looking for a bare bones no HVAC whatsoever system you can eliminate both holes. I have a very rusty A/C Delete box that i'm going to try to clean up and repaint. If anyone is selling one with little to no rust, let me know!
Old Jun 28, 2004 | 07:51 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
just take one from a no AC thirdgen
Old Jun 28, 2004 | 09:23 PM
onebinky's Avatar
Only problem with that is that they are very hard to find, and cost $75 and up if you can find one
Old Jun 29, 2004 | 04:11 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
actually, at least in the northeast, the biggest problem is that any one you find in a junkyard will be severely rusted
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
