My 4th gen console is in. Pics inside
Old Nov 23, 2003 | 03:24 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
It took me 2 days and alot of test fitting and cutting with a dremel to make it work but she is in. had to move the shifter back atleast 2 or more inches. But every thing is in and working except the shift indicator. I couldnt figure out how to make it work so its just in there for looks but it still lights up. I tried to put the power window switches in the ashtray but the shift linkage was in the way so i had to put them up top where you see them. It fits and looks great. What do yall think?
This pic is to prove how damn hot the drive shaft tunnel gets. This is the bottom of the air bag sensor inside the car. I had to remove it cause it was in the way.
Old Nov 23, 2003 | 03:25 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Old Nov 23, 2003 | 04:25 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
Wowee, that's really nice. You did a great job on it.
Old Nov 23, 2003 | 05:04 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
looks really nice. I am adapting a 4th gen auto console like that to work with a megashifter...so far it looks like a lot of dream grinding as well. Will post pics later on it to show you.
Old Nov 23, 2003 | 05:13 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Thanks yall.
Xpend id like to see that when you get done. be sure to post the pics
Old Nov 23, 2003 | 06:19 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Excellent!! I really want to do the automatic in my car. Freaking beautiful man!
Old Nov 23, 2003 | 06:22 PM
camarogirl18's Avatar
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
looks good! you done a good job on it!
Old Nov 23, 2003 | 06:35 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Sonar thanks man. its a pain so get ready for it.
thanks Camarogirl
Old Nov 23, 2003 | 07:35 PM
hrddrv's Avatar
Car: 86 TA
Engine: 305 Carbed. Mainly stock Not running
Transmission: stock
Very nice man.
Old Nov 23, 2003 | 08:35 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
man, those are some great pictures. Looks awesome
Old Nov 23, 2003 | 09:18 PM
M84Z28's Avatar
Car: Black 1984 Chevrolet Camaro Z28
Engine: LG4 305
So how did you adapt the shift boot like that?
Old Nov 23, 2003 | 09:30 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
I took the stock auto shift boot from my 91 Console and stuffed it through the shifter hole in the new console. Then I test fitted the piece on the console and moved the shifter through its gears to see how much slack I needed to leave then I used apoxy glue and glued it to the back of the console panel around the hole. It work very well and as you see it looks awesome.
Old Nov 23, 2003 | 10:53 PM
xpndbl3's Avatar
Car: 1984 Z28
i'll have pics soon don't worry. I love the way your boot looks very nice....plus it hides the gaps well.
Old Nov 23, 2003 | 11:23 PM
SweetRide45's Avatar
I really like how you got the power mirror plate on there. Looks great man!!
Old Nov 23, 2003 | 11:28 PM
1WickedSS's Avatar
I want one! I have never seen anything like that, way good job man, I kinda think it looks better than stock. How hard was it and what all did you have to do? how hard would it be to do it with a sick? how much did the whoe thing cost you ? thanks for any help/advice
1WickedSS
Old Nov 24, 2003 | 12:03 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
looking good blurr. that mirror plate looks familiar
Did you go ahead and change the mirror directions around? Did ya find a way to make it completely work? Mine left and right are correct, but the up and down are now airplane style.
Old Nov 24, 2003 | 02:31 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Looks good. I like your seats too
Old Nov 24, 2003 | 03:37 AM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Very nice.
Old Nov 24, 2003 | 05:38 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
NICE!!!!!!!!!:hail:
Old Nov 24, 2003 | 08:15 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks great
Old Nov 24, 2003 | 09:39 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
1WickedSS
I dont know how hard it would be with a stick.
It wasnt all that hard just a pain in the butt. The base of the auto shifter is taller than the 4th gen ones cause i had to move it back and cut some on it and cut alot on the console to get it to fit around it. I got the console for $50 from a friend and ou can find them all day long on ebay for about that price. I have no clue what all will be involved in it for a stick shift car, so Im sorry I cant help you there. Goodluck though.
Old Nov 24, 2003 | 09:41 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Thanks dude, I just left the mirror control alone. But for some reason when I try to make the mirror go up or down it doesnt always work anymore. My drivers one has never worked since I got the car but the pass. one has always worked until I did this and now it is cutting up.
Old Nov 24, 2003 | 10:13 AM
MNformula350's Avatar
A stick console would be a direct bolt in (except for fabbing the window and mirror switches) to a 85-92 Firebird auto or stick car.
I have a auto but got a 6 speed console and put the switches on a plate i made in the ash tray, the ash tray on a 96 6 speed console in behind the shifter.
Old Nov 24, 2003 | 10:21 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Looks good Dave but what did you do with the power mirror switch?
Old Nov 24, 2003 | 10:22 AM
I didn't have power mirros, if i did i would probably have mounted the switch on the drivers door panel like the Camaro's have
Old Nov 24, 2003 | 11:06 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Ahhh
I might aswell not have them cause my drivers one wont work and my pass. one is starting to act up.
Old Nov 24, 2003 | 11:41 AM
I forgot to mention nice job on getting a auto console installed it looks good.
Old Nov 24, 2003 | 11:43 AM
1WickedSS's Avatar
thank you all for your input, I ll let you know how it goes.
c-ya
Old Nov 24, 2003 | 02:38 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
I was told the 97+ stick consoles are a pretty much direct bolt up into third gens. I'm going a local junk yard in the next couple of days.
Anything to get from the donar car besides the console or any short cuts on the install?
At long last cup holders. Little things do mean alot.
Old Nov 24, 2003 | 04:43 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Thanks Dave
Old Nov 24, 2003 | 04:59 PM
MdFormula350's Avatar
real nice job!
Old Nov 24, 2003 | 11:23 PM
Chet's Avatar
Car: GTA
Looks good, real clean install.
Old Nov 25, 2003 | 10:35 AM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Old Nov 27, 2003 | 09:50 AM
bb92RS350's Avatar
Car: 1992 Cheverolet Camaro RS Heritage
Engine: Vortec Headed Carbed 350
Axle/Gears: 9-bolt with 3.27's
4th Gen console in 3rd gen Camaro
From what it all looks like it only looks like the F-bird guys are doing the console swap. Is it even posible for the 4th gen console to work in a 3rd gen camaro. The console has radio and HVAC mounts and trim plate on it in my camaro and the 3rd gen Firebirds have the radio and HVAC in the dash. How would somebody install just the console and keep the Radio and Heater box in place or would it just not work. But the pics look great wish i had the time and money (mainly money) to do this sway in my car.
Old Nov 27, 2003 | 01:10 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
The only expense you would have is buying the console from a 4th gen and the radio and heater control box from a 3rd gen Bird.
You can put the console in a camaro if you mount the Firebird Radio and heater control box in the Camaro.
However when you buy a 97 and up console, I do recomend you get the cigerette lighter wiring harness so both plugs will work. I bought my console from someone who already had gotten it and I didnt have the harness. SO I had to take the 4th gen cig lighter out and put the 3rd gen one in so it would plug up and work. Im going to go to a wrecking yard soon and get the harness from a 4th gen so both of my cig lighters will work in my console.
Old Nov 28, 2003 | 06:06 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
That looks excellent.
Could you have put the mirror controls between the window switches?
Old Nov 28, 2003 | 06:17 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Nope, not enough room.
Old Nov 28, 2003 | 08:33 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
:hail: Astonishingly well done!
Old Nov 28, 2003 | 09:09 PM
86_cali_ta's Avatar
I got a console from a 02 t/a 6 speed and it fit right into my 86 t/a with absolutely no modification at all. There is however a lip at the very front of the console that sticks out and is noticeable. I will cut it off before I put it back in. I'd take pics but my car's apart right now. -Art
Old Nov 29, 2003 | 12:50 PM
Roads88's Avatar
Went to a couple junk yards and pretty much all they had was in pour condition. Just got a manual one off E-Bay for $112.00 that lookes in nice shape.
I have been going through my shop manual and they don't cover how the consule comes apart.
Can anyone tell me how the shift handle comes off on the auto?
I can feel a groove on the lower front of the handle. can't feel a screw head thow. strange!
Old Nov 29, 2003 | 01:15 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
If you have the same T shaped auto handle I got then there should be a metal C clip that holds the shifter handle on. Its on the lower part of the shifter handle that faces the radio. Take a small small flat head screw driver and stick it in that slotted groove and pry the clip out. It should come out really easy. Then your handle will slide right off the shifter. Its a pain in the *** to put back in the handle but it will eventually go back in. When I say small screw driver I mean a small one, alot smaller than a regular screw driver. Goodluck.
Old Nov 29, 2003 | 03:24 PM
  #42
Roads88's Avatar
Awwwwwwww. thanks dude:hail:
Old Nov 29, 2003 | 03:41 PM
  #43
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Np man, glad I could help
Old Dec 11, 2003 | 11:03 PM
  #44
Roads88's Avatar
Its in, its in , its in.:lala:
Old Dec 12, 2003 | 05:49 PM
  #45
Cool90Bird's Avatar
Car: 91 Formula350 clone
Transmission: Tremec 5spd.
AWESOME!!!!!!!!!!!!!!!!!:hail: :hail: :hail:
I'm in the process of installing an 02 Console in my 90 Formula 5spd. I got some 4th gen switches and made a plate to mount them in the ashtray, I made a blank plate to mount some switches in just above the shifter(elec. exhaust cutout/linelock, etc.). I also just ordered a 4th gen leather e-brake assy and I'm planning on getting a hurst leather **** to match What ya guys think?
Old Dec 12, 2003 | 07:00 PM
  #46
Roads88's Avatar
Thats nice
I don't suppose the forth gen switchs connected right up to the 3rd gen connectors?
If you don't mind me asking, what did you make the plates out of?
When I get the time, I was thinking of going by the dealer ship. There might have been a none smoking option that has a blank that replaces the ash try. It's a long shot but I will give it a try.
Post some pics when you get it in.
Old Dec 12, 2003 | 07:06 PM
  #47
Cool90Bird's Avatar
Originally posted by Roads88
Thats nice
No the switch plugs are different, you just have to re-wire, not a big problem. I used a flat plastic panel that was a VCR top cover(LOL) I liked it because it has a texture to it-wasn't just smooth. If you want to email me I can send ya some more pics BlueTPI@aol.com
Old Dec 13, 2003 | 03:16 AM
  #48
I just used a piece of plexiglass to mount my switches
Old Dec 15, 2003 | 12:58 AM
  #49
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
do any of the 4th gen consoles (either 93-96 or 97-02) fit directly or close enough to our third gen CAMAROS?
Old Dec 15, 2003 | 05:44 AM
  #50
Cool90Bird's Avatar
the 4th gen switches will only work with alot of modification, it'll make a nice looking job if done right. The wiring is different and you'll have to fabricate a way to mount them.
Frozer!!!
Jan 19, 2024 04:55 PM
BADNBLK
Nov 16, 2016 09:12 AM
Casey Meyers
Mar 2, 2016 10:46 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
