Turn signal lever replacement
Old Nov 29, 2003 | 02:34 AM
joshwilson3's Avatar
Old Nov 29, 2003 | 11:22 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just by looking at the switch it does not look like it'll interchange with the 3rd gen console. For the replacement of the switch there is a plug towards the bottom of the steering shaft you have to unhook, once you do this, hook up some wire for a fishline, then just pull the broken switch from the column. You will proably have to tilt the steering wheel up and down while pulling it out and when reinstalling, I did anyways since it hit spots that stopped it cold. It is pretty easy, but a pita since everything is so tight throughout this process.
One more thing, you must not be the brightest light on the tree to publish your sticky finger anticks...next time do yourself a big favor, just keep that kind of info to yourself.
Old Nov 29, 2003 | 11:35 AM
Old Nov 29, 2003 | 05:40 PM
IHI's Avatar
IHI
The plug in for the turn signal switch is down around the area your feet area at, not behind the shroud. You'll have to trace these wires all the way down where alot of the other things plug in below the steering column towards the fire wall-but its actually a foot or so back from the firewall. Like I said, not real hard just a PITA.
Old Nov 29, 2003 | 06:20 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Do a search man. I covered this some time back. All you do is find the connector under the dash(was a grey connector for me), and twist the lever, and it comes right out! Gettingit in was a little different. Just a word of advise, take the "plastic cover" off of the wire when putting it back in and put it on once you have the wire all the way through the coloum. There are a few threads on this subject. good luck Oh yeah, if you want the lever, i have it here. Let me know. I just replaced for a "new" look for my interior, works perfectly.
specialized
Jun 18, 2022 09:26 AM
Caspar
Jun 19, 2016 11:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
