replacing weatherstripping
Old Jan 8, 2004 | 01:04 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
my car leaks like a civ, and my weatherstripping is rotted pretty badly, so i want to replace all of the weatherstripping. i found the part number for the t-top seals (10164133 gmpartsdirect.com) but what else do i need? is the hatch just one seal that goes all the way around? are the doors the same way? does anyone have gm part numbers for the rest of the weatherstripping?
Old Jan 8, 2004 | 01:28 PM
3gc's Avatar
3gc
Car: Z28
The hatch seal is one peice, with a seam right infront of where the hatch latches. As far as i know the hatch seal is discontinued but the door weatherstripping seals are $90 each from gmpartsdirect.com.
The part numbers for the door weatherstriping are:
20350900 - Right
20350901 - Left
Old Jan 8, 2004 | 02:33 PM
Diabolical's Avatar
Engine: 305HO L69
so basically all i need are the 1 t-top seal kit, the 2 door seals, and the 1 hatch seal and that takes care of all the weatherstripping?
Old Jan 8, 2004 | 09:20 PM
3gc's Avatar
3gc
Car: Z28
Well there's the inner and outer window sweeps also, the outer ones are usually all tore up, they're about $20 each, i just got a set for christmas. The inner ones are i think $60 a peice and come with the upper door panel plastic, i'm not sure if they're available new from GM anymore though. And then theres the cowl weather stripping but the ones i've seen are usually in pretty good condition. There's also a little rubber peice on the bottom of the door, they're on the later year cars. If yours dosn't have it it's easy to add and i've heard it helps make the doors feel a little more solid. That's about all the weather stripping on the car, i can't think of anything else beside the little peices on the ends of the tailights hehe.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
