Does this car exist?
Old Jan 13, 2004 | 07:21 AM
Dark Man C's Avatar
Car: 1989 Trans Am GTA
Engine: 350 5.7 L98
Does this car exist or did someone con-**** this 3rd gen fbody?
I have never seen this hybrid before.Maybe it is what it is.Help me out here people. http://cgi.ebay.com/ebaymotors/ws/eB...tem=2453913056
Old Jan 13, 2004 | 07:50 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
That car is a real mess.
To answer your question, yes in 1988 624 Notch Back GTA's were built.
It appears to be an 88 GTA with a 91/92 nose added. It also looks like the factory notch back was added also, because the car has normal back seats. Notchback cars had different rear seats (they had headrests).
I believe AA8 was the RPO for a factory notchback. So finding that would verify if the car was legit.
Old Jan 13, 2004 | 08:52 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
I also hait when ppl right a discription of there car n they cant spell werth a darn or have n e gramaticle skills it dosent look to perfessional and it makes me not wanna bye it becuse it makes me think a little kid rote the discription or sumptin.
Old Jan 13, 2004 | 08:54 AM
FyreLance's Avatar
On a more serious note, the nose is wrong, the back seats are wrong, the taillights are wrong... in fact, you know what, I think this is a regular old 91-92 car with GTA wheels and a notchback added.
I hate when people try to pass cars like this off as a "rare factory car!"
Old Jan 13, 2004 | 09:28 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i've yet to see a legit hardtop gta it should have t tops
Old Jan 13, 2004 | 09:40 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
well seeing how there is a vin. Can u tell by that.
Nate
Old Jan 13, 2004 | 09:42 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I've got 2 of 'em - hardtops that is.
The car on ebay looks to be a legit: 87-88 GTA with an engine swap. The seats don't look right to make the car a true notchback, and the nose on the front is most definitely a swap from somebody wrecking the car. Although, just the parts on that car alone are worth the amount being bid on right now.
Old Jan 13, 2004 | 09:44 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
The Vin # indicates the car is a 1988 T/A/GTA w/ a L98.
Hardtop GTA's are common.
www.gtasourcepage.com
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Heres the vin info.
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Carline Code: F-Body
Carline Series: Trans Am, Formula
Body Type: 2 door coupe (hatchback)
Restraint System: Manual belts
Engine Code: 350 ci V8 B2L/L98 (1987-1992)
7 is the CHECK DIGIT
Model Year: 1988
Assembly Plant: Van Nuys
Production Sequence: 238408
Would it say GTA in the carline series?
Nate
Old Jan 13, 2004 | 09:47 AM
TAdan's Avatar
Car: 1984 Trans Am
Engine: GMPP 350 V8
No, the W in the Vin (5th digit) will only indicate that the car is a TransAm, since the GTA was based off of the T/A, only the W was used.
Firebirds and Formulas have an S in the Vin.
Old Jan 13, 2004 | 11:28 AM
jeriatric's Avatar
That's not a factory notchback car.
If it were, the 10th digit of the vin would be "K".
Old Jan 13, 2004 | 11:59 AM
JT's Avatar
JT
Community Administrator
I know this tech article (https://www.thirdgen.org/newdesign/faq/thirdgen.shtml) says a true Notchback will have the K in the VIN, but I own 3 documented Notchbacks that don't have a K in the VIN. I also have the factory AA8 code on my RPO sticker to identify them as original Notchbacks. I don't know where that "K" in the VIN information came from for that tech article, as I thought that was the model year.
Also, all 3 of mine are hardtops, without the t-tops. Of course they're legit GTAs
Old Jan 13, 2004 | 12:30 PM
Dark Man C's Avatar
Engine: 350 5.7 L98
Thanks guys for the imput and all for this car.
Old Jan 13, 2004 | 01:18 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Same Here!!! The RPO Code AA8 is how you identify a TRUE Notchback!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
matthew911
Aug 12, 2015 09:38 AM
