light switch question
Old Jan 15, 2004 | 01:34 PM
insayne's Avatar
Car: 1984 Mint Z28 H.O.
Engine: 305 H.O
Transmission: 4 Speed Auto =| gettin megashifter
im paintin my interior with hints of blue for my blue/black shceme but i cant figure out how to get the light switch out, i need to paint the pannels the light switch is mounted on but the **** is holding it in and i cant figure out how to get it off? also i poped the button off the shifter but i still cant figure out how to get the actual shifter off the pole so i can take the center consol out. thx
Old Jan 15, 2004 | 01:56 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
for the shifter there is a staple thing on the front bottom of the ****, you can pull that out with pliers.
for the switch what type of car do you have,
Old Jan 15, 2004 | 04:00 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
i bet anything that it is a camaro, they have a switch that has the pull out ****, that type is somewhat easy to get out, behind the panel, on the bottom of the light switch assembly itself, there is a small "button" that u hold in while u pull out the **** and that will allow it to be removed
regards
also since u said u popped the botton off the shifter, i take it your shifter is a top button type? if it is then there is a small c-clip on in there, you'll see it, that has to be removed, than the shifter will come off
Old Jan 15, 2004 | 05:11 PM
HeavyBreathinRS's Avatar
Car: 1990 RS
If it's a Camaro, there's an even easier way than getting inside the dash...
The **** is held onto the shaft by a small sheet metal spring contained inside the ****.
Just take a small (as in short and tiny) screwdriver, compress the spring and voila...the **** pulls off the shaft.
Old Jan 17, 2004 | 07:19 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
When i took my shifter off, i was pulling real hard and almost busted the mirror off when it finally gave. Be careful.
Old Jan 17, 2004 | 08:15 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
just pull on the light switch ****, it comes off, mine on both my cars did atleast.
BRoss99
Aug 10, 2025 05:08 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
