sticky hood
Old Jan 20, 2004 | 03:59 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
sticky hood
well this has been an ever increasing problem with my car.
I pull the hood release, and the hood is becoming ever difficult to actually "POP" open.
Any suggestions?
No, no rust that I can see.
Yes good hood struts
Bigger stronger spring?
make new release mechanisim?
Old Jan 20, 2004 | 07:41 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
I had this problem. I could pull my cable and you could hear it pop but it didn't raise AT ALL. I replaced the cable because the housing on my was broken...still didn't work. Well, after reading another thread a few days ago, and forcing my hood up, I drowned my latch with WD40...I mean DROWNED! Well, lo and behold, the next morning I went outside and it just popped right up. :lala:
Old Jan 20, 2004 | 08:33 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
I just used a little white lithium grease and it's worked ever since
Old Jan 20, 2004 | 09:47 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
If it doesn't open, just lightly hit the front of the hood, and it should pop up. WD-40 is good.....dries up fast tho. I use grease on all the latch assembly, and it seems to fix it for a month or so. Haven't found a permanent fix tho. If it doesn't open, just lightly hit the front of the hood, and it should pop up.
Old Jan 20, 2004 | 10:18 PM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I love grease, you will never find a squeeky door in my car Just put some on there every once in a while, you can spray some I spray some WD40 on the grease for my hood latch and doors, it seems to break it down and help it work its way in.
Old Jan 21, 2004 | 09:42 AM
nolanr0413's Avatar
Car: Trans am
you could try spme graphite dust in the mechanism if you dont wanna use weasle d*ick, or the white grease.
Old Jan 21, 2004 | 09:56 AM
V6sucker's Avatar
Engine: blown up
Lightly? HA I pound that damn thing and it laughs at me.
I grab the edge above the headlights and feel like I am going to rip the freaker off the hood, and it still does nothing. Maybe after a couple min's of shaking it will pop up.
I am thinking of removing the spring, welding on 1.5"X1.5" 1/4 plate and possibly making another hook mechanisim, or reinforceing the one there to stop the damn thing from bending. Maybe 3/16"X1/4"X3/16" strips.
This will be a weekend project, I will post what happens.
Old Jan 21, 2004 | 05:18 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Sometimes mine sticks too. I find that I have to pull the release lever and then push it back in for it to fully unlatch.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
