white face gauges help
Old Jan 27, 2004 | 11:01 AM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
ok, ive learned how to make the gauges, but im a little confused as far as installing them goes. DO you just put them over the stock gauges? if so, woulsdnt that leave the orange tint behind them still? Or how do you take off the old gauge face to put the new one on? Does anyone have pics of the install?
Old Jan 27, 2004 | 11:09 AM
waldershrek's Avatar
Car: 85 Z28
Engine: 383 Stroker
Transmission: 700-R4
when I did mine, I had to take the needles off which is not fun. In order so you don't break them, get a fork and put under the center of the needle where the little black circle is and pry up gently. If you just grab the end of the needle and pry up the needle will snap and then your SOL. As far as the old numbers showing through, as long as you are getting the same numbers, just white face then they will lay right over it and the background won't show.
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
