wiper arm replacement?
Old Jan 28, 2004 | 09:54 PM
wills83z28cfi's Avatar
Car: 07 Silverado
Engine: 5.3L V8, flexfuel E85
Transmission: 4spd. Auto
Axle/Gears: 3.73 locking diff.
I need to replace my passenger side whole wiper arm assembly.
How does it come off? Looks like I may have to pry the thing off.
How easy does it go back on? Anyone have any tips for me? Is there anything I should know about first before doing this. I would appreciate any help or info about this. Thanks. :hail:
Old Jan 28, 2004 | 10:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
They do pry off but, you have to pull out the retainer clip. It's a small tab located at the base of the wiper arm (white arrow below), lift the arm and pry out the clip (not fully, it'll stop, you'll know) then release the arm, it will not sit on the glass. After, gently pry the arm away from the base. There is a keyway so when you put the new arm on, it will be in the same spot.
Old Jan 28, 2004 | 11:28 PM
Car: 07 Silverado
Thanks!:hail: The pic really helps.
Frozer!!!
Jan 19, 2024 04:55 PM
eddie jr
Aug 25, 2015 06:52 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
slade5612
Aug 11, 2015 07:19 PM
