Well now its happened to me.
Old Feb 1, 2004 | 03:56 PM
devianb's Avatar
My once near perfect dash has now been cracked by unseasonable cold weather. This is going to drive me crazy because I will see it every time I drive. Even though I don't plan on keeping the car, I still don't want to see those cracks.
Is there a quick fix to this problem?
Old Feb 1, 2004 | 04:05 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
they make a abs plastic cap to put over it, or you can get the carpet covers from autozone/advance and the like. Or ebay for a new pad.
Old Feb 1, 2004 | 04:07 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
A dash cover is the cheapest fix. Just hide the crack by putting a cover on
Old Feb 1, 2004 | 05:11 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
I feel your pain man I was working on some lighting in my car and had the pad off and was dumb enough to put it on top of my moms car....I went inside...she drove away with it on top of her car....found it the next morning destroyed. Not a huge deal cause I had an extra but like a month after I put it in it got a crack similar to yours!
Those cloth covers look like *** tho IMO, I'd much rather just get a new dash but they cost money...
Old Feb 1, 2004 | 05:49 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
the abs covers look just like it though but they are like 100 for them.
Old Feb 1, 2004 | 08:41 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Movin' to Interior
Old Feb 1, 2004 | 09:37 PM
1-MEAN-T/A's Avatar
Car: 1986 Trans Am
Engine: V8 305 LB9 5.0 T.P.I
Transmission: THM 700 R4 Auto
supergelf has a camaro pad i believe, pm him..ive seen it..in his basement..dont know if he sold it or not or what year it is(i think 91)
Old Feb 23, 2004 | 02:34 PM
DSLDUDE2001's Avatar
Car: 2001 Camaro SS
Transmission: A4
Do you have any pictures of these, and do you know where to get one from?
Thanks!
Old Feb 23, 2004 | 03:06 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I have 2 brand new ABS plastic dash pad covers that are already painted. They match the factory dashpad perfectly. These won't crack! $80 shipped anywhere in the continental US. If anyone is interested just email or pm me.
Old Feb 23, 2004 | 03:37 PM
Car: 2001 Camaro SS
Transmission: A4
Got any pictures? I might be interested...
Old Feb 23, 2004 | 04:58 PM
LUVmy92's Avatar
Car: Camaro
I just found mine cracked too! What a bitch! It figures I start to spend money on her and now things are breaking. I feel your pain, damn I hate a cracked dash
Old Feb 23, 2004 | 06:05 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Keep it polished all the time. It will reduce the wear on your dash because it conditions it. I use Armoral wipes regularly. They also protect against fade.
Although, we already have it going against us having GM dashes
Old Feb 23, 2004 | 06:53 PM
Formula4Speed's Avatar
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
Armoral = Bad
It will dry out the plastic even more so if you ever stop using it you're in trouble...
Old Feb 23, 2004 | 06:57 PM
84_berly_84's Avatar
Car: 84 berlinetta
Mine cracked to but not the pad the actual DASH what can I do?
Old Feb 23, 2004 | 09:32 PM
Car: 2001 Camaro SS
Transmission: A4
Thanks for the pictures drain89! I need to look at my funds, but those covers do look good.
Do you think it is possible to cut the holes out and put some black speaker grill fabric there instead?
Here's the pic that drain89 sent me:
Old Feb 23, 2004 | 11:43 PM
drain89's Avatar
No problem.
As for making speaker grilles, yes I think it could be done relatively easy. Or an even easier route would be to find a set of speaker grilles from a set of 4x6's or probably even better, a set of 4x6 plate speakers and use them. I've thought about doing the same thing myself though.
Old Feb 24, 2004 | 12:15 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
My old dash was badly damaged but i was lucky and found an almost new in mint condition for only 68 dollars. Now thats a good deal.
Old Feb 24, 2004 | 01:26 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Just don't do Like I did to my old pad, got in in a hurry and knocked the corner of the pad off with my knee. But I got a replacement for 70 bucks, After glueing the corner on 3 times and it falling off every few weeks.
But for anyone that lives up north untill someone starts making a dash pad for our cars I would recommend the abs cover, it should last for a long time. here in ga it never gets cold enough to crack the pad on its own, the sun is a different story, but a sunshade and meguires solves that issue.
Old Feb 24, 2004 | 03:45 PM
JR86-TA's Avatar
Car: '86 Trans Am
I have not had a problem with my dash cracking for the two years I have had my car, and I am pretty sure it is the original dash. I use petroleum jelly on mine to moisturize it. And it leaves a shine longer than other products I have tried on interior peices. I just put a light film on the dash, then wipe off the excess with a rag. And my car is just sitting outside right now, and it has been pretty much for the two years I have had it. From extreme heat in the summer, to pretty cold in the winter, and it has held up for me so far. Don't know if I am just lucky, or if my idea works.
Old Feb 24, 2004 | 04:45 PM
Engine: TBI 5.7L v8
Originally posted by Formula4Speed
Armoral = Bad
That was my whole point....
Armoral keeps the dash from drying out/fading, I always keep my interior detailed. Do it once a week.
Old Feb 24, 2004 | 08:10 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Damn, where the hell did you get that?!
Old Feb 24, 2004 | 09:24 PM
GTABABE's Avatar
Car: 87 GTA, 85 Iroc-Z, 92 Camaro RS
Engine: 350, 350, 3.1 V6
Transmission: 700r4, 700r4, 700r4
i don't know what to tell ya man unless you want to get one of those as seen on tv stuff to fill it in
Old Feb 25, 2004 | 09:36 AM
Car: 2001 Camaro SS
Transmission: A4
Email Drain89, he has two of them...
Old Feb 25, 2004 | 10:22 PM
Car: 1987 IROC Z
I still want to know where he got it..
Old Feb 25, 2004 | 11:27 PM
drain89's Avatar
Ebay, It'll run you just shy of $100 for one with shipping plus you'll still have to have it painted. Sold one car before I put it on and am going with fiberglass dash to fit my cage, and maybe a 4th gen dash if I can't fit all these damn autometer gauges in the 90-92 camaro dash, but needless to say.....I can't use other one either. $50 plus actual shipping either one. $20 shipped for the glove box lid cover.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
wanext
Oct 6, 2015 12:18 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
