Can anyone help me with the 180mph DIY white face gauge overlays?
Old Feb 18, 2004 | 08:02 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
I saved this awhile back, it's modified to read to 180mph... I can't recall who did it, but I saved it and I can't get it to print at the size to fit my gauges... and does this look like it's for camaro or firebird gauges? Any help would be great.... and if it doesn't fit my car, at least some of you might get use out of it...
Attached Thumbnails Can anyone help me with the 180mph DIY white face gauge overlays?-180speedobig.jpg
Old Feb 18, 2004 | 08:11 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Thats a Firebird gauge. I don't know how to print it to a certain size, sorry.
Old Feb 18, 2004 | 08:34 PM
OutLaw305's Avatar
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
you could try to use paint. ( i know i know, paint is shotty but this might work.) Open the pic and then use Sketch/Skew. Try to get it close if you have a size like a stock one. Just trail and error until you get it close. It doesnt look like its the right shape so you might be out of luck there. Just tryin to help.
Old Feb 18, 2004 | 10:20 PM
Faded's Avatar
Car: '91 Firebird
If you have photoshop crop the image to just outside the rim of the circle. Then when you print, theres an option of what size, in inches or pixels or whatever, to print to.
Old Feb 19, 2004 | 12:18 AM
SC82TA's Avatar
Car: 1982 Pontiac Trans Am
Engine: Stock carbed 305
Transmission: Stock 200C
In photoshop you have to select the option to print with preview from the file drop down menu and you get this window where it allows you to change the size of the print.
Old Feb 19, 2004 | 12:57 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
it looks cool, but i dont think the mechanical limits of the needle on the firebirds will allow it to go that far down. the needle maxes out a little after the top speed on the speedo.
Old Feb 19, 2004 | 07:22 AM
trendkiller's Avatar
Car: '89/'87/'82 "TransMaro L-81"
Engine: '82 Corvette L-81 (carbed)
Wouldn't the ration between numbers in 10's ( ie 10 - 20, 80 - 90) be slightly off since you'd be cramming 18 numbers (180) in a 14 number (140) gauge.
I don't know. Don't mean to shoot your idea down. Sorry.
Old Feb 19, 2004 | 07:51 AM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
It looks like that ratio is the same if you originaly had a 140 speedo, so it should still be accurate. It just keeps going after 140. But I have noticed that the mechanical limits are at 145 also on the needle. Basically, it would just be for looks in my opinion unless you can some how get around the mechanical limit problem. Anybody know what you would print this on if you wanted it to match the other gauges?
Old Feb 19, 2004 | 07:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: Can anyone help me with the 180mph DIY white face gauge overlays?
you dont modify the pic
you need to set the dots per inch.
lets PRETEND it was 3000 pixles wide.
at 300DPI (dots per inch) it prints out 10" long
at 600DPI it prints as 5" long...
ect...
common sizes are 150, 300, and 600dpi.
alot of people have MS photo editor.... it comes with office....
click properties:
Attached Thumbnails Can anyone help me with the 180mph DIY white face gauge overlays?-dpiproperties.jpg
MrDude_1's Avatar
Car: 91 Camaro Vert
then you get a lil window.... here the pixles per inch (same as dots per inch) is 96.... you can set it to what you need, then print it.
btw the pics are black and white low quality for quicker loading...
Attached Thumbnails Can anyone help me with the 180mph DIY white face gauge overlays?-dpi.jpg
Old Feb 19, 2004 | 08:25 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I made it...
To resize, I think 42%
John
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
ULTM8Z
Sep 16, 2015 09:15 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
