Rust on Rear Hatch Metal lining
Old Feb 25, 2004 | 01:39 AM
91RSHawaii's Avatar
Car: 1999 30th Anniversary Pontiac T/A
My 91 RS camaro has minor rust damage on the exterior metallic lining of the rear hatch, is there any way to fix this cosmetically other than simply replacing it or sending it to a glass shop to be refurbished?
Old Feb 25, 2004 | 11:21 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
Mine has the same thing. I was thinking about sanding it down, masking off around it, and painting it. I'm at a loss for what to paint it with though, i'm guessing its not the base/clear thats on the rest of the car, and I don't want to use a rattlecan anywhere near the car (except on the wonderbar, but that can be out secret ). Its not bothering me too much now, but its on my list of little things to do to make the car look a little nicer, right after the window sweeps and a stupid speeding ticket.
Old Feb 25, 2004 | 02:47 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
sanded painted mine 5 years ago with dupli color high gloss black paint. Used a sealer primer under it from dupli color both rattle can.
Opened up the glass and sanded it down to the metel removing all the little rust spots. Primed and painted, it just has started to fade but no rust has came back. And it should be an easy light sand and paint now to make it glossy again. Also did the t-top trim the same way.
Old Feb 25, 2004 | 02:57 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i did the same think duplicolr rattle cans works real good. just tape and paper off everything as not to get overspray all over the place. sand seal prime and spray, could even change from black if you wanted that my even look kinda cool.
Jeff
Old Feb 25, 2004 | 03:03 PM
nolanr0413's Avatar
Car: Trans am
i might bu buying one with rust on it, im worried it will be bad, worst case the piece is rusted and i need a new one.
Old Feb 26, 2004 | 12:07 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
What about removing it completely?
Can you remove that piece of metal without ruining the structuraly integrity of the window?
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
