Has anyone added factory gfx to thier non gfx'd car?
Old Mar 1, 2004 | 02:37 PM
devianb's Avatar
I was contemplating adding gfx, and I know the cars that came with gfx had a 2" bracket welded on the lower part of the body where the side gfx attatch to. Has anyone added gfx without the bracket? If so, how did you do it? Does it sag?
Old Mar 1, 2004 | 03:55 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
Yea i put 85-90 T/A gfx on my 84 but i used the bracket. It soesnt have to be welded i just used self tapping sheetmetal screws and i think mine came out great.
When i first bought my car after primer--->
Attached Thumbnails Has anyone added factory gfx to thier non gfx'd car?-468197_1_full.jpg
Old Mar 1, 2004 | 04:00 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
After gfx ------->
Attached Thumbnails Has anyone added factory gfx to thier non gfx'd car?-468197_sdfgdf28_full.jpg
Old Mar 1, 2004 | 04:04 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
Month later
Attached Thumbnails Has anyone added factory gfx to thier non gfx'd car?-picture055_01mar04.jpg
Old Mar 1, 2004 | 09:39 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
You don't hve to use the original bracket, a 2" x 1/8" x 4' piece os flat stock works just well (that's what I used anyways).
Just adding the gfx w/o anything will cause them to sag over their span in time. Just having them off the car on a irregular surface will deform them slightly. While they will return to normal shape once mounted, you will want to mount them to 'recontour' them before painting. They also won't be quite as rigid leading to the paint being able to crack & chip easier.
Old Mar 1, 2004 | 10:18 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
It's been done.. I like how Firebirds look without GFX though.. But they look nice with them too...
Old Mar 4, 2004 | 01:01 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Originally posted by raffi4
After gfx ------->
Those rims are nice. They look like the ones I want. Are they Welds? Can you give info on them? Thanks.
Old Mar 6, 2004 | 02:22 PM
raffi4's Avatar
Car: 1987 IROC-Z
Engine: 305 LB9
They are american racing rims still have them sitting in my garage. they're 14's but dont really seem lioke it when their on the car.
colton_carlson
Mar 8, 2019 12:21 PM
fonzie85
Aug 13, 2015 11:50 AM
mizz0313
Aug 12, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
novaderrik
Aug 10, 2015 12:44 PM
