4th gen wing on a third gen
Old Mar 1, 2004 | 06:17 PM
1987ws6tpi's Avatar
4th gen wing on a therd gen
has any body put a 4th gen high rise ta wing on a 3rdgen camaro ? if so post a pic please i an thinkng of doing it thank you
Old Mar 1, 2004 | 08:03 PM
88 Formula 355's Avatar
Car: 1991 Z28 Camaro
Engine: 355 Solid Roller
Transmission: Turbo 400
Yes I have, you will have to take the sides and mold them flat because they have a rounded bottom for the 4th gen hatches, then you'll have to recess the front side down so that it sits flush against the glass and curve the ends of the tips around so it sits flush against the glass and you'll have to extend the center posts down so that they will touch the hatch to bolt down. It is a very good looking mod however, I love the way my car looks, I've been saying I have been going to post pics forever I've had the car done since late october and I still havent even taken a pic of it! I promise I'll get one up really soon
Old Mar 1, 2004 | 08:09 PM
1987ws6tpi's Avatar
hay thanks man , is it hard to do or should i hve a body guy do it? would you mind if i did that?
Old Mar 1, 2004 | 10:17 PM
By all means go for it man, I like to see guys like me that like to put work into their cars to get exactly the look that they want. But if you dont know much about working with fiberglass you'd probably be better off to take it to a good body shop. I work at a body shop myself and I'm guessin they'd probably charge around $300.00 for all the work but I promise you it'd be well worth it. Also you'll have to weld up your old holes in your hatch and drill some new ones but you'll figure it all out in the process and if you need any help at all just post and I'll help you in any way I can....
Old Mar 3, 2004 | 01:38 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
(or you can just buy the 4th-gen replica spoiler and be done with it..........)
Old Mar 3, 2004 | 01:44 PM
1987ws6tpi's Avatar
were can i get 1 for a camaro and a ta wing???
Old Mar 3, 2004 | 05:56 PM
Yea, if you wanna be a lazy @ss u could just buy the aftermarket wing, but I dont think it looks as good as if u have an actual 4th gen molded to your hatch, The wings are actualy fairly easy to find at salvage yards, I picked mine up for like 75 bucks and put just a little labor into it and it looks awesome...
Old Mar 3, 2004 | 09:55 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Some lazy asses don't have 4thgens littering the junkyards around the to get such a wonderful deal.
The only difference between the aftermarket & the OEM is the brake light anyways.
Old Mar 4, 2004 | 09:36 AM
87F383's Avatar
Car: 87 Formula 350
Engine: LS1 in Progress
Axle/Gears: 3.70 9 bolt
My aftermarket 4th gen wing has a center LED brake light.
Old Mar 4, 2004 | 09:40 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
http://www.gtfiberglass.com/Our_Products.html
Old Mar 4, 2004 | 12:13 PM
FyreLance's Avatar
Old Mar 4, 2004 | 04:26 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
...The only difference between the aftermarket & the OEM is the brake light anyways.
That, and the center 2 posts are longer on the aftermarket one so it is a true "bolt-on" without modification to extend the posts.
I think the aftermarket brake light is a lot better looking than the factory one.
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
