will a diff door fit/shut the same?
Old Mar 4, 2004 | 10:09 PM
FireRed91Z28's Avatar
Car: 91 Z28
Engine: currently 350...BUILT 383 soon
Transmission: T56 w/4.10's
there is an 89 RS camaro the same exact color and condition as my 91 Z28. recently my friends dad backed his truck up into my doo and made a good amount of damage. i can get the door from the RS for farely cheap and i plan to keep the money i get from his insurance. i was wondering if changing the door would make it shut differently or not fit like the original? my doors still shut like they were new but i guess that all has to do with the hinges etc..right? so will it be fine?
Old Mar 4, 2004 | 10:36 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Yeah, and now would be a good time to install new door pins.
Old Mar 6, 2004 | 01:30 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
It should fit right up with no problems. If you can, check the doorpin condition before removing it from the other car.
Old Mar 6, 2004 | 10:12 AM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
what are door pins?
Old Mar 6, 2004 | 06:45 PM
jaredjames's Avatar
Car: 1982 Berlinetta
nevermind door pins. they're talking about the pins on your hinges. but of course when you change out doors your obvilously going to have the hinges that are on the new door. Just check door gaps and body lines, you should be fine; you can even use your passenger side as a reference.
Old Mar 8, 2004 | 05:42 PM
Marc 85Z28's Avatar
It will work fine. I have an 88 Trans Am drivers door on my 85 Z28.
Veaceonee
Sep 29, 2016 08:15 PM
LC2 TECH
Interior Parts Wanted
Jan 27, 2016 08:38 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
carattini
Sep 10, 2015 07:46 AM
rudolphschenker
Sep 4, 2015 02:41 AM
