what is the vacuum switch connected to the temp controls?
Old Mar 18, 2004 | 07:37 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
Connected to the cold-hot slider is a two way vacuum switch that I can't find on any diagram. It has a pink and a grey hose going to it. It was hissing so I disconnected it and didn't notice any difference in hvac operation, though my A/C is disconnected currently.
Old Mar 18, 2004 | 07:47 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Will this help?
Attached Thumbnails what is the vacuum switch connected to the temp controls?-vacuum1.jpg
Old Mar 18, 2004 | 07:59 PM
Car: '87 Camaro LT
Engine: 355 L98
Yeah, it's the circle on the controls that B and G lead to. What does that do?
Old Mar 18, 2004 | 08:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
When the slider is switched all the way to cold, it sends vacuum to the heater control valve and prevents coolant from being circulated to the heater core.
Old Mar 18, 2004 | 08:56 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
It is the rotary selector switch.
Attached Thumbnails what is the vacuum switch connected to the temp controls?-vacuum2.jpg
Old Mar 19, 2004 | 01:30 AM
Car: '87 Camaro LT
Engine: 355 L98
That's kinda weird because what I did was disconnect the switch from the linkage and then turned it to off (cold) which is the position that it doesn't hiss in. So this means that coolant is not flowing through the heater core, right? Thing is, though, it gets just as hot as it did when the switch was hooked up.
Old Mar 21, 2004 | 03:46 PM
Car: '87 Camaro LT
Engine: 355 L98
Ok, so my heater core started leaking yesterday. Any chance this is because I've had the temp on hot yet the vacuum switch has been on the cold position? Or is it just a coincidence?
eightsixseven
Dec 16, 2024 01:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Bull86
Aug 10, 2015 05:43 PM
