'89 Back hatch adjustment?????
Old Mar 19, 2004 | 08:15 AM
Chevy Muscle's Avatar
I have an '89 IROC and the back hatch leaks near the roof when it rains. I usally keep it garaged, and don't drive on rainy days, but sometimes I get stuck.
It looks like the back hatch is missaligned since the gaps are not consistant across the top near the roof.
How best can I adjust it??
I took the plastic cover off from the inside roof a year ago, I saw the bolts, but it didn't look like it was adjustable.
Is that what I need to loosen and adjust?
Please Help!
Old Mar 19, 2004 | 12:56 PM
Faded's Avatar
Car: '91 Firebird
I'd like to know this as well. My hatch has an 'overbite' and I was wondering which part needs to be adjusted, the hinges or the deck lid?
Old Mar 22, 2004 | 02:26 AM
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
hey guys same prob here
when you open the hatch look in the crack at the very top youll see 4 nuts in there thats where you adjust it at.
thats what im having to do to mine.
thomas
Old Mar 22, 2004 | 06:24 AM
Screamin'87GTA's Avatar
Car: Trans Am GTA
Transmission: Rebuilt 700r4 with stage 3
My brothers maro has an overbite also, but like chevy muscle said, it doesnt look like the are adjustable, there are no grooves to move it back and forth?
Old Mar 22, 2004 | 08:23 AM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
If you are going to adjust the hatch loosen where the hinge is mounted to the body not the glass,it may break that way.Also you'll have to unbolt the gas shock supports for the hatch glass too,makes it easier.Get somebody to help you with this too.
Old Mar 22, 2004 | 10:26 AM
91z
isnt it where its mounted to the glass where you adjust it at? i could be wrong but on my notchback thats the way it is.
Old Mar 22, 2004 | 11:54 AM
91Zman's Avatar
Car: 1991 Z28
the hinge has the caulking too where mounted at th ebody,but..
See the problem,besides risk of breakage,is that there is a seal(gasket) plus some kind of caulking(around the holes in glass) where the bolts go through.When you loosen the bolts and the hinge moves around that will most likely break the caulking loose and will be no good.So then you will have to re-caulk that opening and at the same time later readjust the hatch,causing further headaches. This all just my theory/opinion but it's something to think about.
Old Mar 22, 2004 | 12:50 PM
ok 91z
like i said i wasnt sure just going by how mine looked it doesnt have any caulking or seal around the big bolt thing that go through the top of the hatch on my notchback. just wanted to let you know that so there wasnt any hard feelings.
thomas
Old Mar 22, 2004 | 05:54 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Changed the back hatch on mine before getting the car painted. The window glass has fairly large holes that allow adjustment when you loosen the bolts. Best to take the bolts clear out and clean everything up real good, light layer of RTV when replacing bolts, might paint the outer caps while off. The rear part of the hatch is a different story. The metal part seems to be glued as well as bolted to the glass. If the glass gap is even all around and the trailing edge is out of line, big problem.
Old Mar 25, 2004 | 06:13 PM
Car: Trans Am GTA
My brothers seems to have the "trailing edge" problem. The glass seems to have correct clearance all the way around. Just seems to be the edge...
Old Mar 25, 2004 | 07:11 PM
DC87GTA's Avatar
Car: 1987 Pontiac GTA
Engine: ZZ383 HSR
Transmission: T-56 6-Speed Manual
Axle/Gears: Ford 9", 3.89 TrueTrac Posi
If the glass edge is off around the edges of the hatch then all you would need to do is adjust the hinge bolts to align it with the body. If the rear panel has the "overbite" from the rest of the hatch, and no water leaks in then you have to remove the metal part from the glass then reposition it so that it lines up with the rear of the car. Just depends on what is wrong with the hatch. I have not yet done the sencond one but will hopefully be doing it this summer to correct the overhang. I have attached a link for the tech article explaining how to do this procedure.
Hope this helps
Rear Hatch Alignment 101
Old Mar 29, 2004 | 07:31 AM
Car: Trans Am GTA
Thanks for the link it looks very helpful!
customblackbird
Aug 15, 2021 10:16 PM
madsv1000
Aug 20, 2015 06:45 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
