Racing Harness
Old Mar 20, 2004 | 09:38 PM
JoshuaBP's Avatar
Car: 1985 Firebird
Racing Harness
I don't have a rollbar or cage in my car but i do want to put some racing harnesses in, I just really like the look of them. Is there any posible way of putting them in without a cage or rollbar that won't compramise safety? thanx
-Josh
Old Mar 20, 2004 | 11:44 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
you can bolt it to the floor
Old Mar 21, 2004 | 01:15 AM
JoshuaBP's Avatar
Car: 1985 Firebird
so if i bolt it to the floor and i get into an accident, it will work as good as the stock seatbelts? also, how do i make it long enough to bolt to the floor?
thanx again
-Josh
Old Mar 21, 2004 | 06:28 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Get a NHRA Rule Book And it explains the angle that the 5 point mounts the the cross bar on the cage. This is important because if incorrect it could apply pressure incorectly and break your neck. That is why Drag Strips Tech are so Picky. Safety First. point blank period
Old Mar 21, 2004 | 06:34 AM
deadtrend1's Avatar
somesay bolting to the floor will compress your spine supposedly.
Old Mar 22, 2004 | 06:56 PM
I heard it wasn't safe also...unless it is done correctly...but I don't know the info on it..
Old Mar 24, 2004 | 08:07 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
No matter how you do it, bolting them to the floor is unsafe.
Old Mar 24, 2004 | 07:59 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
bolting the 5 point to the floor is unsafe and will cause more damage to your body than just teh 3 point...if u want teh 5 point the u need the bar that goes across behind your seats to bolt it to. i learned that on the tv show Trucks
Old Mar 24, 2004 | 11:44 PM
JoshuaBP's Avatar
Car: 1985 Firebird
Thanx a lot guys for your help, iguess i gotta get the bar.
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
gta892000
Sep 16, 2015 12:37 AM
abray1
Sep 14, 2015 08:18 AM
buckshot63
Sep 10, 2015 09:15 AM
Billy Decker
Sep 4, 2015 03:46 PM
