Door handle has a wire hanging down, how do I fix it?
Old Mar 24, 2004 | 09:12 AM
Mike89GTA's Avatar
Ever since I got my car there's been this little wire clip thingie hanging off the door handle. It still operates flawlessly though. How do I fix it?
Old Mar 24, 2004 | 03:08 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Replace the handle. That little 'wire' is actually the 'spring' that keeps the handle from flopping/rattling. On the underside of the handle, there are 2 cast in retainers that hold this spring in place. The casting breaks, the spring falls, the handle rattles.
Old Mar 24, 2004 | 03:13 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
duct tape lol I have the same problem with my drivers side handle. How hard is replacing the handle?
Old Mar 24, 2004 | 03:18 PM
Mike89GTA's Avatar
Here's a pic
Old Mar 24, 2004 | 03:19 PM
Mike89GTA's Avatar
Maybe I'll just cut it off It doesn't seem to rattle, or maybe I'm just used to it. The next time I drive my car I'll see if it rattles.
Old Mar 24, 2004 | 03:26 PM
deadbird's Avatar
Engine: TPI 305/ v6
Originally posted by Mike89GTA
[B]Maybe I'll just cut it off
lol... I yanked mine off my camaro with vice grips. The handle didn't actually flop around (as per norm.) untill I did that. I suppose you could duct tape it though
mike... to replace the handle you will have to take the inner door panel off and the plactic vapor barrior off (if present). With the windo up, you'll see the backside of the handle (not easily though). It's held by 2 10mm (or 13mm.. I forget) thread cutting nuts. There is also the lever rod. There is a plastic clip at the handle that pops off to remove the rod. Remove that & the nuts and replace the handle, installation is reverse of removal.
Old Mar 24, 2004 | 03:34 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
cool, maybe i will take that task on after I replace my window motor
Old Mar 24, 2004 | 03:54 PM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
That pic looks just like what my car used to look like. Until Officer ROBOGRIP stepped in and saved the day. I'd call him if I were you.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
BlackTopKing
Aug 19, 2015 12:13 PM
