HOOD latch stuck
Old Apr 3, 2004 | 05:21 PM
lubranoc's Avatar
HOOD latch stuck
A week ago I posted how I was having a hard time getting my hood to open, so after some suggestions I went ahead and got some new hood struts (neither worked before anyways), latch and hool latch wire and handle from the dealership.. so . sure engouh go to open it to put all these new groovy parts in.. and now I can't get the hood to open at all.. when I pull on the wire I hear the little thing click.. but no opening.. even if I am pushing on the hood from under the car while someone else is pulling the wire.. nayone have any suggestions or cool trip to opening a hood ?
Chris
Old Apr 3, 2004 | 06:32 PM
Krazzycowgirl's Avatar
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Once you get things open WD40 it really well. Then pull the Cable back & forth for about 10 times.
Old Apr 3, 2004 | 06:40 PM
lubranoc's Avatar
Still nothing
Played with it for another 30 minutes..nothing. please help. Also for once I get thigns open how shoudl I grease the latch before putting it in and with what ?
thanks
chris
Old Apr 3, 2004 | 07:19 PM
nolanr0413's Avatar
Car: Trans am
um , you need to have someone pull the latch , and then you bang on the hood. Thats about the only way , unless you can get under the car and do some magic.
Old Apr 3, 2004 | 07:24 PM
lubranoc's Avatar
banging on hood
Ohh.. there has been some major hood banging going on today... and nothing.. when I bang on the hood all it does click the latch back.. sounding like it locks it again..
Chris
Old Apr 3, 2004 | 07:56 PM
3gc's Avatar
3gc
Car: Z28
It's possible to open the hood by sticking your hand up from under the car and moving the latch mechanism while you or someone else pulls up on the hood. I've done this a few times sticking my hand through the grill on my old camaro.
Old Apr 3, 2004 | 08:12 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
Depends on what car you have or the year but T/As and firebirds there's the pull the handle and lightly tap a foot from the front of the hood(in the center) or after you pull the cable lift up on the hood.With a camaro you can do the hood tap thing or crawl underneath and try ro reach the thing where the cable is connected to and push it and hopefully that'll work.
Old Apr 3, 2004 | 08:20 PM
lubranoc's Avatar
car
Sorry I forgot to mention I have a 92 firebird, I can reach the cable.. and I can reach the cable and the little handle that gets pulled when you open it.. and I played with those forever.. but got nothing.. hopefully knowing what car I have will insipre you to give me enough hints to get this punk hood opened up tommorw.
Chris
Old Apr 3, 2004 | 08:32 PM
91Zman's Avatar
Car: 1991 Z28
Well when I had that problem with a berlinetta. I had I crawled underneath w/a screwdriver and stuck it between that cable attached part in the direction it moves( to the driver's side) and the hood popped open,sometimes I did it by hand/finger while I pushed up on the hood as I lay there on the ground.Sorry to say that there is really no other way,that I know of, to pop open a stuck hood.
Old Apr 3, 2004 | 09:38 PM
Morley's Avatar
while someone pulls the hood cable, SLAM the passenger door, this should release the hood if the latch is actually unlatching.
Old Apr 3, 2004 | 09:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
When you get the hood open finally (you CANNOT hold the latch open and open the hood at the same time for some reason.. I don't know why, even if you have a friend pulling the latch and you on the hood if you think that is what I meant by that) check the alignment of the hood to the fenders at all four corners and then the latch post to the latch itself. It don't take a lot of misalignment to screw up the works there. And then use white lithium grease on the hinges and latch... works much better and lasts longer than WD-40 and that all-in-one stuff. Might even want to use it on all the latches and hinges of the body while you are at it...
Old Apr 3, 2004 | 10:03 PM
*F-BodyFanatic*'s Avatar
Car: 1991 Pontiac Firebird
Engine: TBI 5.7L v8
Transmission: Modified T-5
Occasionally I have the same problem with my hood. Try this:
You stand on one side, while someone else stands on another. Pull on the top corner (near the windshield). Mine usually pops up after a few minutes of tugging.
Maybe the same thing, may not be.
Sometimes I love it... sometimes I hate it. Sometimes I see it as an added security feature, incase someone sets off my alarm, they can't snip the wires from under the hood (even tho there are other places to snip!). But other times, it's a pita. Esp if I'm alone and trying to open my hood for some reason.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
