Some pictures of paint job in progress
Old Apr 29, 2004 | 08:13 PM
  #51
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm going to attempt to do the same... minus the garage
Old May 18, 2004 | 11:35 PM
  #52
3gc's Avatar
3gc
Car: Z28
Figured i'd update this thread. I'm very off on my guesses on when i'll get to stuff, i just repainted the passengers door yesterday lol, but i also painted the fender so i guess i'm ahead of the game. I'm happy with the results, got some stuff in the clear, but hopefully it'll sand / buff out. I also painted the driver side door jam. Hope to have the drivers door and fender as well as hatch painted tomorrow. This car isn't going to be perfect but once it'll look 1000 times better then it did last summer. When i'm finished i'll post a before and after.
Old May 19, 2004 | 11:45 AM
  #53
jaredjames's Avatar
Car: 1982 Berlinetta
hey i had asked my teacher if he ever heard of a 72 hour window and he said yeah and also martin seniour has a week window on some of its paints. sorry bout that man, urs shouldn't peel
Old May 19, 2004 | 12:20 PM
  #54
3gc's Avatar
3gc
Car: Z28
That's a releif lol. Thanks for checking. I already have two coats of base on the drivers door, fender and hatch. I should be done in the next hour and a half or so with the next coat of base and clear. I'll post pics when done.
Old May 19, 2004 | 01:56 PM
  #55
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
It looks like you did an great job of re hanging the doors, the seams seem perfect. Great job so far.
Old May 19, 2004 | 01:58 PM
  #56
3gc's Avatar
3gc
Car: Z28
Some new pictures. Tomorrow i'll take some pictures outside so it'll shine alot more. There is no light source in this picture beside the sunlight getting through the canopy.
Old May 19, 2004 | 02:06 PM
  #57
3gc's Avatar
3gc
Car: Z28
The drivers side seam isn't as good as the passengers. I was having a hard time getting the holes to line up so I wound up "tweaking" the body side lower hinge. The lower part of the drivers door sticks out slightly. I gotta order a new one because the roller is screwed up anyway. I won't be getting that for a few months though. Not really looking foward to removing the hood, fender and lower hinge pin with new paint.
Old May 20, 2004 | 09:35 PM
  #58
3gc's Avatar
3gc
Car: Z28
Put some stuff back on the car today. Installed new door weather stripping, new passangers exterior door handle, new outer window sweep, reinstalled the triangle seal. Bolted up and lined up the fenders, for the most part anyway. I need to work on the rear lower bolts, the mounting tabs are bent back. Installed the inner fender liners. Btw, it's a bad idea to do that without the fender completely bolted in. It caused me to chip my paint on the drivers side door edge, oops . Also put the rear bumper emblems on.
Old May 20, 2004 | 09:47 PM
  #59
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Man your car is coming along great. I love all the work that was put into it & seeing you document it. Keep it up
Old May 20, 2004 | 10:39 PM
  #60
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Remember to add "flex" agent to your paint on the GFX and nose cone. That way it won't crack if it bends a little.
Jim.
Old May 20, 2004 | 10:42 PM
  #61
3gc's Avatar
3gc
Car: Z28
Flex agent was added to the primer. I was told BC/CC paint dosn't require flex additives.
Old May 20, 2004 | 10:48 PM
  #62
Car: 89 RS
I don't have any flex agents in my BC/CC paint job & after 1 year it's still going strong with no cracks.......Knock on wood
Old May 21, 2004 | 04:15 PM
  #63
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
You probably haven't rubbed up against anything yet. Good on ya for adding it to the primer, though.
Jim.
Old May 21, 2004 | 08:36 PM
  #64
InsaneTA's Avatar
Car: 92 TA WS6
Engine: 305 TP1
DITTO!
Old May 22, 2004 | 10:08 AM
  #65
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i repainted my car about 3 1/2 yrs ago and didnt add any flex additive in my paint and the only cracks i got was from tappin the nose on this one concret colume at work.
the car looks great, i wanna tare my car down like that but i gotta find a beater first.
Old May 24, 2004 | 11:30 PM
  #66
3gc's Avatar
3gc
Car: Z28
I'm hoping this goes to a second page soon as i'm sure this takes forver to load on a 56k. Anyway, the end is near. I'm hoping to be driving this thing by the weekend or early next week. Here's some new pictures.
I painted the cowl flat black yesterday. Today I installed the new t-top center bar and t-top weather stripping. I still need to adjust the windows but it looks like it'll seal well. The Donut is on the rear because the rims are going to get sand blasted, repainted, and have new tires mounted on them this week.
Old May 26, 2004 | 03:41 AM
  #67
smokeingGTA's Avatar
Car: 89 firebird GTA
Engine: 350 T.P.I
Transmission: 700-r4
Did you sand all the old paint off when you first started or did you use paint stripper? Isn't it better if you paint everything at once or does it turn out ok if you go peice by peice, also what kind of paint gun are you useing? Yours is turning out great from what I can see.
Old May 26, 2004 | 09:26 AM
  #68
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Awesome color, dude! :hail:
Car's gonna look awesome when you're done!
Old May 26, 2004 | 10:46 AM
  #69
3gc's Avatar
3gc
Car: Z28
I sanded down to primer in most areas. I tried a chemical stripper on the doors because there was a lot of paint but it seemed like sanding was actually quicker. I used a DeVilbliss gun I bought from harbor freight. I'll admit it looks better in pictures but over the summer I'll touch up and redo certain spots that didn't come out great. Here's a crappy piture from yesterday.
Looks like i'll need to adjust the door some more also. With the all new weatherstripping it's b*tch to close. Hopefully they'll wear in. Basically just the hood and the drivers side spoiler peice is all that's left. If the rims aren't done this week, i'll get a used tire for matching 15" rims i have on there for the time being. My goal is to drive it this weekend.
Old May 26, 2004 | 11:57 AM
  #70
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Wow, thanks for showing tons of during and after pics! I really really want to do this to my car... but, once again, no garage! (Or skills, or knowledge, or ... ... ... you get it)
Old May 26, 2004 | 02:18 PM
  #71
3gc's Avatar
3gc
Car: Z28
I had none of that when i started either. I bought the canopy and the tools and learned from friends.
Here's a before picture...
Old May 27, 2004 | 01:14 PM
  #72
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
damn man, really nice work. i wish i had the time to do that stuff
Old May 28, 2004 | 12:04 PM
  #73
camaroguy8923's Avatar
Car: 89 camaro Rs
Engine: 305 V8
looks great
Old May 30, 2004 | 11:28 PM
  #74
3gc's Avatar
3gc
Car: Z28
I've been driving it for the past few days. I forgot how much fun this car is. It's not complete yet. Hood needs to be painted this week and i need a new spoiler peice but that's about it. It should be done next week or so.
Few new pictures:
dustint209
Sep 9, 2015 08:09 AM
chubsworth
Aug 26, 2015 02:34 AM
neekolzun
Aug 24, 2015 04:59 PM
kyle5647
Aug 7, 2015 03:08 PM
