Arm Rests Mounting Screws
Car: Red Rooster
Transmission: M5
Hi all.
I just picked up a pair of very nice armrests from a 85 maro because my were peeling off. (i have a 89).
When i tried to install them it looked like the upper screw was too short.
Did anybody do the swap and found the same thing or ami doing something wrong?
Thanks.
Thanks.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Daniel,
The only thing you might be doing wrong is using the screws from the 89 arm rest. I have a set of each style and the 85 model armrests have a longer (about 1" more) plastic insert in them than the 89 does and uses a longer screw.
Car: Red Rooster
Transmission: M5
Originally posted by Trickster
[B]Hello Daniel,
[B]Hello Daniel,
Are they full of it or not??
Could someone confirm that??
Car: Red Rooster
Transmission: M5
I told them that i want the upper screws and they said it is same number..
It would be awesome if you could check the lenght.
thansk.
thansk.
Car: Z28
I checked the part number cd i have and the part numbers are actually the same for both, 20310728. The top screw is M6.3x1.8x60 and the lower ones are M6.3x1.8x35.
Car: Red Rooster
Transmission: M5
Thanks for help guys. That is weird. If 85 ones are longer than why would it be the same part number? So the ones i need (the longest ones) are 8x60, correct?
60 does it mean 60 mm in length??
I had the same problem. I ended up drilling out the older armrests. Kinda like countersinking the upper hole. No problems,and you'd never know it wasn't original.
Car: Red Rooster
Transmission: M5
Car: 1989 Iroc-Z
Engine: 5.7L TPI
In answer to the first question, it is 60MM.
For the second question, the screw sits a little deeper in the newer style armrests than in the older ones so he drilled the screw hole a little deeper and wider.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
