DIY paint job.
Old Apr 13, 2004 | 12:39 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
DIY paint job.
not exactly Thirdgen related but might end up being. i come here to ask because you guys know your stuff.
i am getting a 1979 Ford Bronco for free. it is completly rust free, has a 3" lift but is in primer right now and needs a new paint job. along with some body work. im looking for a site that gives good tips and info on doing this that or if you guys can give me some tips and info that would be great. i have access to the tools and resources to do it so that isnt a problem.
Old Apr 13, 2004 | 06:32 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
sand it all the way down as far as you can go, primer doesnt seal against water, so there will be rust under the primer, so hit it with a da with some 100 grit, then 220, reprime, by now it should all be done with body work and ready for paint....
Old Apr 13, 2004 | 08:57 PM
92MaroRS's Avatar
how many layers of each(primer,base, clear) should i use. also any tips to make it look the best. i dont want to spend a whole lot on a paint job but i dont want it to look like total crap ither. i dont plan on wet sanding it too much as orange peel wont bother me on this vehicle. its gonna be pretty much my beater vehicle. thanks for any tips. also there are some spots that i will end up having to use bondo on prolly any tips on how to get that to look good also?
Old Apr 14, 2004 | 01:47 AM
maverick351ci's Avatar
Car: 1985 Firebird
marro look at my posts you will find some usefull information
i posted a huge rant one of them
Old Apr 14, 2004 | 01:48 AM
Car: 1985 Firebird
https://www.thirdgen.org/techbb2/sho...hreadid=234209
heres the post at the verry bottom you will find alot of information
good luck
Old Apr 15, 2004 | 06:48 PM
Charged350's Avatar
Car: 87 IROC Z28
yeah, sort out his info on that page and thats about what i woulda told you more or less
3 coats of each should do fine for this car by teh way
Hotrodboba400
Dec 10, 2019 07:07 PM
69GTOby
Apr 18, 2016 02:34 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
ULTM8Z
Sep 16, 2015 09:15 AM
