How much weight reduction with a fiberglass hood???
Old Apr 14, 2004 | 04:34 PM
Z RATED IROC's Avatar
Car: 89 Camaro
I am looking to get some weight off of the front end of my 89 Camaro by replacing my stock steel hood with a Fiberglass hood like a ASSD or Harwood. I want to use my stock hardware and struts. How much weight will I save???
Thanks...
Old Apr 14, 2004 | 05:54 PM
Pew's Avatar
Pew
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
You'll only end up saving about 20 pounds or so estimated never weighed the two to compare.
Old Apr 14, 2004 | 08:23 PM
Irhal's Avatar
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
20 pounds is being very generous... with a solid fiberglass hood, you don't save much weight our sheet metal is awefully thin and fiberglass is rather heavy... if you want to change the hood for weight purpose only... don't...
Old Apr 14, 2004 | 08:38 PM
25THRSS's Avatar
I didn't weight the difference, but maybe I should. My harwood 3 inch bolt on hood felt a lot lighter than the factory steel hood. I could lift the thing with ease, but I had to get help with the steel hood. Before I get everything painted I'll weight the 2 to see the real difference.
Old Apr 14, 2004 | 10:56 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i would think around 50 pounds? no idea really, just know i've removed soo much weight from mine that the front sits 1.25 inches higher than it did before i start gutting stuff out of the nose. so it's really noticable now. gonna see how it works out with true duals....or it's time to start hacking half a coil.
Old Apr 15, 2004 | 02:16 AM
Kandied91z's Avatar
are you kidding me. unless i have a factory reject my stock 91l98 hoos was extremely heavy. takes at least 2 people just to move it around let alone set it up properly on the car.
my ss ascd hood is easily very lightweight in comparison. my car raised 1" with the stock hood off although i'm using 200lb springs. while i think it's a waste for stict weight reduction it's significant to say the least...more so then any other mod. try to find worn out hood shocks though as good working ones will put to much stress on the fiberglass.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
