tires
Old May 3, 2004 | 07:43 PM
digital_burnout's Avatar
Car: 91 camaro z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 410
tires
whats the widest size tires i could fit out back without having to worry about any rubbing or etc.
Old May 3, 2004 | 07:55 PM
Bandit5's Avatar
Depends on the size of your wheel... tell me what tires you have on there now and I can probably figure it out.
Old May 3, 2004 | 08:12 PM
Car: 91 camaro z28
Engine: 355
Axle/Gears: 410
i put 265/50/15 like 4 days ago and it looks like theres still plently of space for a wider tire.
Old May 3, 2004 | 08:53 PM
Bandit5's Avatar
Assuming you have stock wheels, 15 x 7... I'd never put on tires any wider than that. They are gonna be too wide for the wheel. As far as tire width and clearance, you can easily fit a 17 x 9.5" wheel with 285 wide tire with no clearance problems. i don't think you will have problems with your 15 x 7 wheel.
Old May 3, 2004 | 09:01 PM
Car: 91 camaro z28
Engine: 355
Axle/Gears: 410
iv got 15 x 8 aftermarket rims.....would 285 fit that or too wide?
Old May 4, 2004 | 01:40 AM
onebinky's Avatar
You don't want the tread width to be wider than the rim itself. It might look badass, but traction will suffer with the wider tire because you can't get an even footprint.
Not to sure on the 285 section, you'd have to punch it into a tire calc along with sidewall profile and rim size and see what it says.
Old May 4, 2004 | 10:50 AM
snipcod's Avatar
Car: 1984 z28 Camaro
If you put 285's on, could that only fit in the rear?
Old May 4, 2004 | 02:26 PM
Bandit5's Avatar
285 will fit... barely. But I would stick with the 265... those tires are perfect for the wheel they are on. If you put 285 on the front, you will probably have some rubbing problems during hard cornering.
Old May 4, 2004 | 09:01 PM
onebinky's Avatar
I know you can fit up to a 295 back there. I had them on a 8" rim, but like I said traction will suffer. Depending on backspacing, typically the widest you can run in front is a 245 if you're going to maintain stock tire height.
Old May 4, 2004 | 09:49 PM
Car: 91 camaro z28
Engine: 355
Axle/Gears: 410
alright..im probably gonan stick with the 265..thanx for the help
Old May 5, 2004 | 11:48 AM
snipcod's Avatar
What would the side wall size need to be with 265's. And would you be able to lower it with that wide a tire?
Old May 5, 2004 | 12:55 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
what is the WIDEST tire i can run on a 16" or 17" rim that will fit int he rear without any fender modification?
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
