What to do about this rust.
Old May 19, 2004 | 05:43 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I have 3 spots of rust on my whip, this is one.
Old May 19, 2004 | 06:05 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
this is the worst spot.
Old May 19, 2004 | 06:15 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Depending on what it looks like under and behind on the door. I would first sand out the area, and use a spot sand blaster to remove the rust. and depending on how had you can either cut out and weld in a patch.. would on the door would be interesting to make sure the panel doesn't warp. or use a bit of fiberglass over it instead. and finish it off and repaint .. As for the rear fender part. it's a bit tough to tell .. but probably the same process as mentioned above.
Old May 19, 2004 | 07:19 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
and this is the last spot. I'm wondering if anyone can tell me what the best way to get rid of these spots would be and how would I do that?
Old May 19, 2004 | 11:12 PM
Morley's Avatar
Spot sand blasting is the best way to tell how bad it is after the rust is removed. If you sand it you can end up sanding through high spots and actually hiding some of the rust.
Old May 22, 2004 | 07:20 PM
2out_The_Left's Avatar
for the wheel well, i'd just cut it well above the infected area and either get another quarter to weld in its place, or mold one. for rot spots you MUST cut away the infected pieces or they will keep returning. the others look small enough to sand. i'd have that done asap, rot spreads quickly. after owning a rotted car, i will never even think about buying one again. i'd rather have a perfect frame then a 10 second rotted car
Old May 22, 2004 | 09:50 PM
LostInPlace's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
what is "rot?" I've only recently become interested in this stuff, so please don't laugh. I know what rust is (duh) but I'm not familiar with the term rot used in regards to metal.
Old May 22, 2004 | 10:13 PM
luke-gr's Avatar
Lost, its the same thing.
Old May 22, 2004 | 10:17 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Really bad rust that has eaten away at the metal. As in a rusted hole.
Old May 23, 2004 | 07:59 AM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
POR-15 works great on rust but yours is in some highly visible areas. I would also find a donor car and cut out some metal and weld it in place. If you cant do that try getting a couple quotes from a body shop.
Old May 23, 2004 | 07:42 PM
its not the same. rust is the flaky stuff that can be sanded off. rot is when it eats a hole through the body and becomes thin.
por15 is the greatest rust prevention paint out there. it can't be used for body panels though. mostly just undercarrage and rear ends. they say it loses its potentcy when exposed to sunlight, thats why i call it gizmo paint.
Old May 23, 2004 | 07:46 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
You can use por15 on body panels, but you have to prime and paint over top of it. If you leave the paint exposed to sunlight the UV rays ruin its effectiveness against the rust.
Old May 23, 2004 | 07:48 PM
i stand corrected.
Old May 25, 2004 | 02:04 PM
Car: 1991 Firebird
Engine: 3.1L V6
Transmission: auto
thanks for the info, i guess i should've been able to figure it out on my own. i've got some rust on my car and i'm afraid some might be rot i'll have pics up soon so you can all share your mighty wisdom. sorry for intruding on the thread
Old May 25, 2004 | 08:08 PM
if your quarter looks that bad, i would check the floor boards of the car. i por15ed my whole undercarrage, including the rear end, to insure that it would not rot away. i suggest you get under there and hit the floor boards with an angle grinder and a knot brush at the end, soak them in metal ready, and por15 the whole under side. it takes a long time, but its WELL worth it. next time you go under there, or bring the car to the shop for work, you'll be able to see yourself in the reflection of the floor boards i'm very pleased with the por15 product and wouldn't use anything else on the under side of my car after seeing the results.
my86bird
Oct 23, 2015 12:20 PM
FueledSoul
Sep 30, 2015 09:18 PM
m00n420
Sep 11, 2015 02:39 PM
Stryker412
Sep 7, 2015 09:11 AM
3tas4me
Sep 4, 2015 01:45 PM
