switch panel
Old May 24, 2004 | 04:31 AM
bubba377's Avatar
switch panel
does anybody have the link were i can buy a switch panel that goes in place of where the ash tray is .I had seen it a couple months ago but can't remember who the name of the co. is .THANK YOU THEY HAD A REALLY COOL SWITCH SET UP
Old May 24, 2004 | 10:14 AM
nolanr0413's Avatar
Car: Trans am
check out 84customz28 i know he has a panel for switches there. Im pretty sure that he made it himself, i dont think thier are any that are made to go there.
Old May 24, 2004 | 11:29 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
here ya go man
Old May 24, 2004 | 03:19 PM
nolanr0413's Avatar
Car: Trans am
how does the "POWER PLATE" hold in there, is it just a contact fit or are their some screws im missing.
Old May 24, 2004 | 03:24 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
I'm not sure how it's mounted, however it does look nice. But "Power Plate" is referring to what the switch operates, not the panel the switch is mounted on I believe
I used a thin piece of aluminum and shaped it with a Dremel, drilled all holes I needed (1 green LED, 1 red LED, and 2 stereo 1/8" jacks, & mounting holes), then painted it GM satin black. The flap still closed over it and it looked very nice. I know that may not help but I'm just saying I had to make one.
Old May 24, 2004 | 03:36 PM
Engine: 5.7
I took a piece of bare aluminum and cut it exaclty the same size as the ashtray lid. Then, I sanded all the edges down, just enough so it fit very tightly. Then, expoxied it form underneath. Before I expoxied it and everything...I drill all the holes for the LED's and for the switch. I used to have a different switch set-up...it was set down in the ashtray like TPIROC stated...but..I couldn't see the LED's very well and it was a little harder to get to...so..I don't away with the lid and everything and made it this was. I can get to it very easy and plus, it looks cool
Old May 25, 2004 | 07:18 PM
bubba377's Avatar
thanks guys !!! but this was a panel that was advertized for sale it had some cool rocker switchs on it but it was like 40 or 50 $ all I really need is the switches I can make the plate myself.I think it even had one panel with a nos arming u know flip the cover to get to the switch
Old May 26, 2004 | 01:00 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I'll post some pics of mine when I get back to my computer. Basically, you just cut a piece of black ABS to fit the ashtray, and then cut holes for the switches. Then just use some ABS cement and glue it to the bottom of the shifter panel. That way you can keep the stock ash tray cover. I did it in both my car and my brother's. If you're needing switches, just try an auto parts store or radioshack.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Dialed_In
Aug 20, 2015 01:45 PM
