THE longest iroc
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
thats got to be a photoshop but thats still one of the coolest things ive ever seen. And if those t-tops popped off :hail: sign me up for two of em.
Car: 82 Camaro Z28 Indy 500 Pace Car, 98 Firebird
Transmission: TH200
I found a little info on it, its about half way down the page.
http://my.net-link.net/~dcline/limonov1.htm
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
most of the converted limos on that page look real, but the IROC just doesn't! Check out the DeLorian though... very interesting limo with rear gullwings!
Car: 1991 Z28
Yes, it's always possible it's a photoshopped picture....but as
CDN_87IROC mentioned there are all manner of custom limos these days. If you automatically dismiss it as a manipulated image without any verifiable proof, I must say I find that a bit obtuse.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Upon close inspection of the picture.. it's a photoshop. (though I'd love to see a real one.. that would be serious stylin' for a formal event for one of us thirdgenners
The shade of color on the sail panel doesn't line up, and it's obvious where an extension took place. The rocker ground effect has lines in it that should be mere pixels.. again, extended (but done rather well). The rear window simply does not appear capable of retracting into that itty-bitty door. Limo tint is usually not applied to the driver's window. The lower half of the back edge of both doors have an almost identical graphical glitch in them. And last, but not least, the bricks in the background look like they've been played with too.
It does, however, look pretty nifty
)The shade of color on the sail panel doesn't line up, and it's obvious where an extension took place. The rocker ground effect has lines in it that should be mere pixels.. again, extended (but done rather well). The rear window simply does not appear capable of retracting into that itty-bitty door. Limo tint is usually not applied to the driver's window. The lower half of the back edge of both doors have an almost identical graphical glitch in them. And last, but not least, the bricks in the background look like they've been played with too.
Car: 1990 Camaro
Engine: 355ci
also the fact that its slammed to about 1 inch from the ground and also i dont see a limo like that having t-tops. But if that did exist when i get married it would be in one of those
Car: '82 Z28
Photoshop
There's a section of bricks that really give it away because they're identical.
There's a section of bricks that really give it away because they're identical. Supreme Member
Car: 1991 Z28
Transmission: 4L60 automatic
Yeah,photoshop.You can see a line right behind the 1st door and the brick part as previously mentioned.Magnify the pic and you can see what I'm talking about.
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
Lets not overlook the door locks on the rear door and the fact that you can see a drivers seat through the back window. That's without enlarging the pic.
Engine: LS1, Scrap
And here's why I don't believe it... if the *grass* is photoshopped, chances are the car is too. But that's a good one (ugly roofline tho)
Car: 88 camaro RS
Engine: that thing under the hood?
Transmission: a what????
i really dont see why some of you dont belive that there is one out there somwhere. yes those two are PSed but i do belive there is one out there some where. the things some car nuts think of when they are bored
Car: 85z28,
That house look like the same with the window tooked out of the one on the left.U can see the tree in the middle.I agree with yamahaguy91 I'm sure someone has done it or atleast tried really hard to make one.
Engine: LS1, Scrap
I don't doubt it's been done.. I'd just love to see a real picture.. guess it's time to stop talking smack about the photoshops and do my own research.
EDIT -- and Google says it doesn't exist. limo/limousine/stretch/stretched + camaro/iroc/iroc-z/z-28/thirdgen/3rd gen.... nothing.
Car: 2002 Camaro SS
Engine: LS1 350 V8
Transmission: Automatic 4 Speed
That would be cool to see some actual pictures of them, I would definitley pay to take one to prom or just out for a cruise.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I use to work for a limo place that made most everything them self. They were famous for the double decker bus here in Toledo. That two 8hr employees stacked n welded from junk busses. It was really amazing at what they could do with mostly junk cars. The rolls had a chevy 350 drive train.
But I always thought that hotrod limos would be a better draw for business. 57 chevy stretched out with a monster blower and
tires. real hot rod limos that can turn heads at the car show, run good at the track, and smoke em off with 15 people in the back.
There really inst any laws on limos or most any custom build. long as it passes a basic inspection it can be driven. I seen a show where they said Ford was the only real limo maker and they were trying to stop the custom builders.
Car: 89 camaro Rs
Engine: 305 V8
i am sure that here is one out there but these are not any of them
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The windows are dead give away. Even a tinted window had some reflections. THat is what makes the white one harder to tell. the window work was great.
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
Originally posted by Kandied91z
plenty of iroc limos out there....3 in my area alone with 2 being black and one red. never seen a white one yet though.
i was the one who PS'd the original
https://www.thirdgen.org/techbb2/sho...ight=iroc+limo
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by deadbird
How about a 'vert limo ? (did this a long time ago)...
Car: 1985 Trans Am
Originally posted by Gumby
Any every 5th time you open the rear doors the hing pins need replaced and re aligned from the 500lb doors.
mustangman65_79
Aug 11, 2015 03:17 PM
