C&C t-top headliner
Old May 29, 2004 | 11:52 PM
SARswmr's Avatar
C&C t-top headliner
Does anyone know how to replace one of these. I had to pull mine because it was trashed and the backing board is not usable. Has anyone used a hardtop one and trimmed it to fit. If so how did it work, any pics or suggestions. I've been searching but only come up with having a custom one made, $$ that I don't have, and using the hardtop trimmed to fit but there was no resulting info.
please give any suggestions if you have had to deal with this before.
Tim
Old May 30, 2004 | 12:21 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: C&C t-top headliner
Tim
One pic coming up,actually 3 pics.
Old May 30, 2004 | 12:32 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
2nd pic-Thats exactly what i did.Bought a used hardtop headliner & trimmed it to fit.It wasnt that difficult.I even made some t-top visors with matching material i purchased at a upolstery store.
Old May 30, 2004 | 12:34 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Old May 30, 2004 | 01:00 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
a few more.here is a cropped viewthe front/rear edges.
Old May 30, 2004 | 01:06 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I also overlapped the headliner here under the plastic trim.This helped to get rid of some squeeks/rattles.
Old May 30, 2004 | 01:10 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Heres one with the t-top installed.
Old May 30, 2004 | 01:20 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
overhead shot of the center portion.
Old May 30, 2004 | 01:23 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
last one
Old May 30, 2004 | 12:32 PM
JestahX's Avatar
Car: '85 Z28 Camaro
I am going to be recovering mine and want to know how you got yours to fold over the edges so well. Did you sew it or glue it or what? I want to do mine in like a vinyl or leather.
Old May 30, 2004 | 05:16 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
No glue or stitching.Just cut the headliner form a hard top car so it overlaps past the t-top edges by a good 2-3 inches.Then tuck it inbetween the weather strip & metal body(channel) of the roof.Afterward trim any excess headliner.Just try to work the material as far down into the channel so it doesnt slip out later.It helps too of the seals are out of the channel.The way i did it was first i cut the headliner,then i removed the seals,clean the channels,applied the silicone,tucked in the headliner as i layed down the new seals.Let it set.
Old May 30, 2004 | 08:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I contacted the Sunroof Doctor which has alot of parts for the C&C T-tops about the headliner in my 86 which has come apart. They stated that all C&C did was take the hardtop backerboard and headliner and cut it, then put the trim pieces around the edges to keep it from fraying. The headliner was glued onto the backerboard just as the original one was.
Old May 31, 2004 | 01:04 AM
JestahX's Avatar
Car: '85 Z28 Camaro
What type of glue did they use? Because after so long it doesn't hold anymore. Im thinking epoxy or gorrilla glue would hold better, maybe fiberglass&resin it on every few inches? Thats what i was maybe thinking. Im not sure how well it will still seal if you put it under the weather stripping. I have my doubts about it such as water or something getting under there and rusting it out? I dont know... Not that im too worried about rain since when im finished with my car it wont be driven in the rain or snow period.
Old May 31, 2004 | 10:27 AM
CaysE's Avatar
3M General Trim spray adhesive or Fast Tack Trim adhesive. Both work very well for glueing the material to the backerboard and will not sag.
Old Dec 16, 2004 | 01:48 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
what are those plastic things on the headliner? what are those used for? i don't have them on my C&C ttop.
Old Dec 16, 2004 | 02:18 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Very nice job with that headliner there! I have C&C tops as well, and though my headliner is not sagging the plastic trim peices that hold the tops in broke and it rattles like crazy now. I was thinking that when I get around to it I'd try and design something similar to the GM ASC T-top adjustable holes. That might get rid of some of the squeeks.
Old Dec 18, 2004 | 04:41 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
He has that pop top T-top.
Good information. I'll need it later.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
m00n420
Sep 11, 2015 02:39 PM
