How long can u wait between base coats
Old May 30, 2004 | 02:57 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
Well here I sit in the middle of a 3 day weekend and I run out of paint and basemaker. Is it okay to wait more than the recommended time to re-coat the base? I've already got 2 1/2 coats on but there are some spots that reflect the light differently and I think another full coat would fix that.
I'm repainting w/the stock color (teal metallic) and using Dupont Chromabase Premier. Sanding again on the base does not sound like the right thing to do - is it okay to wait 48 hours to put on another coat??
Old May 30, 2004 | 10:55 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
No I would wet sand the base coat with 2000 grit and finsh base coat then clear
Old Jun 2, 2004 | 03:41 PM
jaredjames's Avatar
Car: 1982 Berlinetta
hes right have fun sanding! u would be fine just using a red scotch brite pad.
Old Jun 2, 2004 | 04:14 PM
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
imo
he should refer to the product sheets considering some companies do not recommend sanding there basecoats he might have to sand back down to primer and then reshoot the color. just my $.02.
thomas
just found this look under chromasystem technical manual. http://www.performancecoatings.dupon..._CBaseBsct.pdf
Old Jun 2, 2004 | 07:31 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
you can go nuts wetsanding or you can just sand it down with 320 grit and wipe it down with prep sol and shoot ore basecoat and then clear....try to have all teh supplies this time so you dotn have to do it ten times over.....
morrow
Jan 13, 2024 12:29 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Gunsbee
Sep 7, 2015 07:10 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
