Shaving antenna
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Shaving antenna
Got a few ?'s. Can i just weld in a piece of metal and fill it in with body filler or is there an easier ay to shave it? Also, where can i find the kit that puts it in the window? Is that what everyone does when they shave it?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
If yo uknow how to weld and know how to do minor body work...shaving an antenna is a breeze. I just welded the hole up, the used duraglass, bondo, the glaze to finish it...as simple as that. I have no antenna of any kind right now..I'd like to know where to get one too....
Car: 1992 Firebird convertible
Engine: 3.1
my friend shaved his antenna and then went to autozone or something and got an antenna with the wire on it ran the wire through the dash and then fished the antenna into the defrost vent, he said has pretty good stations and defrost works fine.
but if u really want one for ur window go to http://www.jcwhitney.com
L8er
L8er
welding is the best way to shave the antenna. when i shaved mine, i almost bought an antenna that goes in the windsheild, but i just ended up putting the antenna inside the dash. i get extremly good reception still
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
i put mine in my dash, and i love how it looks now.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Shaving antenna
wow, this thread was brought back from the dead...
Car: 85z28,
I put my ant. under the dash pad. They do make a real thin one that u can put in the head liner. But mine works fine under the das pad
What i did was went to circuit city, bought a remote antenna /w a booster. The antenna part is a box that messures out to be 4x1x1(LxWxH). I mounted it to the upper part of my windshield that is not visible from the outside. It works great!
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I was thinking of mounting my antenna in the engine bay underneath the fender lip.
Mine is "shaved" i guess, i put on new fenders and never drilled for the antenna
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
