Water Leak - Where?
Old Jun 11, 2004 | 04:42 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Water Leak - Where?
Hey guys,
I noticed something kinda disturbing today, and now its starting to bug me.
Its been raining quite a bit lately, but today I noticed that there was a small pool of water in my passenger side foot well. It was about 1/4" deep.
Now, my car does have t-tops, but I don't think thats where its coming from, because its under the dash board, right in front of the firewall.
Whats really starting to bug me, is that I can't see any kind of path the water took to get there. There is no wet "track" down the carpet on the firewall, or down the side of the door, or anything like that, and the area around the tops is dry. And AFAIK, there are no holes in the floor anywhere either.
Where cool this be coming from? Its in that dip in the floor around where the cat is under the car. I really wanna get this fixed before it becomes a more serious problem.
Old Jun 11, 2004 | 06:39 PM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
its water for sure ? not colant?
well all i could really think of is this because i think this is the reason my car has a small water leak nothing major
in the pic wehre i put a white circle the corner of the window is there a tiny little gap between the car and the molding ive noticed many camaros with that problem if there is that could be it just alittle gap maybe quarter inch
Old Jun 11, 2004 | 07:00 PM
camaro of solar's Avatar
not too sure how camaros are but I know my buddy's GF had a problem similar to what you explained...and it turned out the AC Drainage was some how clogged and my mechanic friend jsut cut the little elbow outside where it drained under the engine bay and replaced it with a tubeing....
Old Jun 11, 2004 | 07:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
It could be a leaky windshield. The water will run down the firewall. I would also double check that your heater core is not going to detonate.
Old Jun 13, 2004 | 01:28 AM
Air_Adam's Avatar
Its not the heater, because thats not even got hoses hooked up to it right now, just plugged the inlet and outlet after I unhooked it from the engine. And its definitely water, rain water. There is no coolant in it, and it smells like rain water. If you live in Sask, you know what I mean, lol.
I'll take a look at the windsheild next chance I get (too dark right now). Thats about the only thing I haven't checked yet. I looked under the car and found no holes, and my firewall, well, what I could see from under the hood, couldn't see the other side, was dry and has no holes, so thats not it either.
If it does turn out to be the windsheild, how would I fix that? Its not cracked, so it would have to be a leak around where its sealed to the body. If I find something, can I just use gasket silicone (its black, so it should blend in pretty well) to seal it?
Old Jun 13, 2004 | 04:19 AM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
iv had these leaking problems also. if u dont have ac, then u most likely have the same problem i did. first open the hood, look on the passangerside, under the heater box and above wheel well check for rust holes in the firewall there....if nothing there then i have a couple more ideas, so let me know if u have A/C or not and if theres rust holes there, ttyl
Old Jun 13, 2004 | 07:19 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You will have to have it re-sealed. It is not that big of a deal and is fairly cheaco to have done since you are not replacing the glass why you are at it. My 98 sierra truck does the same thing but I am to lazy to fix it since it is a work truck.
Old Jun 13, 2004 | 08:03 PM
Air_Adam's Avatar
Ok, well, I checked around the windsheild and can't find any leaks there. I even put some water over the edges and can't see anything seeping though.
I did at one time have AC, but its been long since removed. I don't have an AC delete box though.
Old Jun 13, 2004 | 09:01 PM
what u can also do if ur up to it is take teh dash out and check in the cowl there...actually im not sure what it looks like on ur car as u had AC but took it out...anyhoo check in the cowl behind the dash cuz i did and it had a whole buncha dirt and crap in there, almost like leafs had been in there and actually decomposed into dirt but i took that shiat out and found a few rust holes patched those up and now it doesnt leak...
Old Jun 13, 2004 | 11:27 PM
Air_Adam's Avatar
Worth a shot... I don't have to go to work tomorrow, So I might have time. Only thing is, there is no wet "track" going down the carpet and the bottom of my dash (above the pass. feet) isn't getting wet either, and it doesn't look like there is anywere for it to come down from.
I'll take a look though. I really wanna fix this before I end up with even more rust problems.
Old Jun 13, 2004 | 11:29 PM
my84firebird's Avatar
Car: 1984 Pontiac Firebird
Engine: modded 5.0
Transmission: modded 700r4
same here. I had a leak in the same spot that I couldn't trace, every time it rained my passenger floorboard was soaked. Turned out to be a tiny hole in the firewall behind the dash.
Old Jun 14, 2004 | 12:13 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
dry out the car and take it through a high pressure touchless car wash.
then youll see the water come out :lala:
Old Jun 14, 2004 | 04:37 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
I had the same problem and it turned out to be the main wiring harness that runs from the eng. bay into the pass. side interior.
I removed the pass. side kick panel and had my wife hose down the pass. side windshield while I looked with a light. The water was running down the wiring harness and when the harness changed directiuns (up) the water dripped onto the carpet. Man it took awaile but I found it.
Auggie
Old Jun 14, 2004 | 05:56 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
my cousin had this same problem , cept he has a gtp, the weatherstripping thats on the hood was loose so it would allow water to get into the hood and onto the firewall and it would go down the vents and into his car...i would check that , i hate water leaks, there always hard to find
Old Jun 14, 2004 | 06:06 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
Adding my input.. same for me.. it was where I had my amp power wire coming through the firewall, water was going down the windshield, along to and down the firewall and following the power wire into my car where the water filled up.
In my case it was the front and back driver side foot wells that filled up.
Submerged my rockford amp under about 4 inches of water.
it lived
Still pounds today even..
:lala:
Old Jun 14, 2004 | 06:24 PM
Air_Adam's Avatar
Auggie
Wow, heh... never thought to look there. One more thing to check out.
Thanks!
BTW - keep the suggestions coming
Old Jun 14, 2004 | 10:31 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I had the same problem. Ended up being the widshield. You couldn't see the water when you put the hose on it or even high preasure water, but that was where the leak was.
The problem is if you go to get the windshield replaced and it's rusty under there they won't warantee it.
Old Jun 15, 2004 | 08:00 AM
LaxStreetRacer's Avatar
Car: 91 Z28
How is the weatherstripping on that window? Ive owed 2 thirdgens and on both on the passenger side that stupid azz rubber triangle piece over time comes loose and moves up to high then leaves a permanent dent in the weatherstrip wich always leaks when it rains hard/gets washed.
Old Mar 23, 2005 | 11:02 PM
cozhavok's Avatar
Car: 1985 Camaro Z28
Engine: LB9 V8
Well I had a ton of water in my car in the rear in the middle and in the front. So I stripped it and ran a hose on the roof and found all the spots. The front passanger side is leaking from the wiring harness so how do I fix it? The other came from t_tops so I got a t-top gasket kit. The others in the back are from the flat spots in the gasket. Then 2 other leaks are coming form the rear where the hatch struts bolt into the hatch. How do I fix those. Any help will be great. Also how do I REMOVE the mildew smell???
Old Mar 24, 2005 | 09:36 AM
Auggie's Avatar
Well, on the main wiring harness leak (this may sound crude but I thought what the heck nobody will see it any how) I built a dam around the harness with RTV and duct tape. I hosed it down and the water runs down the harness, hits the dam and drips on to the ground. I left my car out in a down pore and no leaks.
Auggie
Old Mar 24, 2005 | 11:41 AM
Briansz28's Avatar
Cozhavok- do you need a new hatch seal? Mine looks in bad shape but doesn't leak. I had lots of water/mildew and....old puke in the back of my car when I bought it. Only way to get rid of it was strip all the carpets & seats- found nice replacement stuff. But before you re-install make sure all the leaks are fixed and wipe down w/ bleach & water solution. If your soft stuff- carpet, seats aren't too bad, you may be able to use an upholstry cleaning machine.
Or spray the whole inside w/ Febreze
Old Jun 6, 2005 | 07:01 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
i know this post is alil old but i wanna to keep it saved i have the same problems and my buddys to.going to check every single one and post results
Old Jun 6, 2005 | 07:42 PM
Air_Adam's Avatar
So who blew the dust off this thread?
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
tommy z-28
Oct 6, 2015 10:58 PM
st.evel07
Sep 19, 2015 09:24 PM
84redta
Sep 19, 2015 09:58 AM
