few probs....
Old Jun 16, 2004 | 07:44 PM
89caliMaro's Avatar
Car: 1989 Camaro Rs
Engine: 5.0 TBI
few probs....
mpg gauge doesnt work,oil gauge doesnt work and right blinker doesnt work either do the low beams.... can i fix myself or should i take to mechanic?im a beginner in cars....have a few friends that r pretty good with cars..
Old Jun 16, 2004 | 09:30 PM
nolanr0413's Avatar
Car: Trans am
well its up to you , do you need them to be fixed right away? DO you wanna learn how to do it? I mean their are a bunch of things you need to answer.
Old Jun 16, 2004 | 10:28 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
Re: few probs....
Have you checked out obvious things like broken wires, fuse panel,etc.? You can take it to autozone/checker and they can do a basic test on your electrical system as well for free altho i dont know if that would help you. Im not too keen on when they switched from mechanical to electric speedos but if its mechanical (which i doubt) you may just need a new cable. As far as the blinker not working when you flip the switch for it inside does the indicator light stay a solid color or what? It could be you just need a new bulb. The only thing i dont know about if you would want to do yourself is the oil guage, because if its not just a bad wire you may have to take your dash apart.
Old Jun 17, 2004 | 07:53 PM
89caliMaro's Avatar
Car: 1989 Camaro Rs
Engine: 5.0 TBI
when i put the blinker on it stays a solid color....i want to learn to do these things but im kinda scared of messing some stuff up...and i meant mph not mpg i dotn know why it doesnt work the Rpm gauge works...havent checked any wires or anything...just got the car 2 days ago.. well i have 3 months before i get my license and i have many thing i need to work on so what things do you recommend i start on first? i also have body/framework problems check here
https://www.thirdgen.org/techbb2/sho...hreadid=246336
Old Jun 17, 2004 | 07:57 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
i read it as mph anyways, so its all good.
for your blinker all you need to do is change out the bulb. thats what the solid light means. check all your connections and fuses and change out that bulb and then get back on here again. sometimes in your trunk theyll be extra bulbs laying around ( i always leave some in in case one goes out i can get it fixed real quick, the previous owner couldve done the same) otherwise go to any auto store and they only cost a few bucks. if you dont know which one to get, just ask.
Old Jun 17, 2004 | 08:19 PM
89caliMaro's Avatar
Car: 1989 Camaro Rs
Engine: 5.0 TBI
alright ill get started ont hat rigth now thnx for the info.
MrDude_1
Feb 15, 2005 08:47 PM
ponykiller
Nov 1, 2003 07:06 AM
