Hatch Glass Leak
Old Jun 22, 2004 | 05:24 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Hatch Glass Leak
I have a bad leak coming in between the glass and the sheet metal at the lower part of the hatch. It soaks the trunk.
Is there a seal between the glass and sheet metal ?
Old Jun 22, 2004 | 09:23 AM
nolanr0413's Avatar
Car: Trans am
ah yes, i just changed the rear window on my trans am and their are two pieces that go under there. You cant get either of them from gm , so you gotta do what i did, first piece, go to newgmparts.com . The part number is 20328200. You need this one. And the other, this stuff is the gooey stuff. Its buetyl adhesive strip. It isnt sold under this name . What it is , is windshield sealing stuff. Now they use gel to do windshields . 3m makes the stuff u need , the exact name it " Ribbon Sealer" Auto glass replacement kit. i got the 3m part number too, since im lookin at the box right now . 08614, i got the 3/8 inch kit, the shop manual calls for 5/16 but it looked too small. Now i dont drive my car in the rain unless it has to go to some place, exhaust shop, window tiniting. Stuff like that . I did that project a few days ago and ive been letting it sit in the sun everychance i get , since i have a garage. I didnt know i could get the first strip , i know its cheap but shipping will be 10 or 6 , i forget , but get the strip anyway , it covers the advesive strip so if it doesnt look perfect no one can see it. I dont know to this day if mine will leak. So i dont know what to tell you , but this is what your supposed to use to do it. SO i dont see why it wouldnt work . Hope this helps. If you need anymore help pm me.
Old Jun 22, 2004 | 09:47 AM
Tom91RS's Avatar
Car: 91 Camaro RS
Engine: 305 tbi
Thanks Nolan !!!
I was thinking it was just a bead of sealer. But I think the leak is probably the secondary seal. Probably dry rot or something.
Anyway thanks for the detailed help.
Tom
Old Jun 22, 2004 | 10:11 AM
nolanr0413's Avatar
Car: Trans am
by sealer i hope you dont mean silicone, i did it with that first and it doesnt look good. So do it the right way and you wont have to do it again if you do it right the first time.
Old Aug 5, 2005 | 09:02 PM
cozhavok's Avatar
Car: 1985 Camaro Z28
Engine: LB9 V8
newgmparts.com is a bad link. I have the same problem I think. My car is parked on a down grade and my trunk is soaked. I put a new GM trunk weather stripping on and it seems to be leaking where the lower part of the hatch meets the weatherstripping. Looks like some black things on the hatch. ANY HELP PLEASE!!
Old Aug 9, 2005 | 06:17 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
I used two pieces of tape across the window and the metal deck lid, and then laid down a thin bead of clear silicon. I smoothed it and then peeled the tape immediatly before it dried. If you take your time and use some finess it comes out to the point you hardly notice, and it seals.
Good luck
Sparrow
Old Jun 10, 2006 | 04:22 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
hey does anyone know what the gm part i used looks like , i got someone who needs the piece and gm says its discontinued and i cant for the life of me remember what it looks like , hes got the ribbon banner but i dont know what the little seal is .
Old Jul 11, 2013 | 04:50 PM
bennettcvcu's Avatar
Car: 1988 IROC-Z
Engine: L03 to L05: 350 TBI
Transmission: MD8: 700R4
Axle/Gears: GU2: 10 bolt/2.73
Re: Hatch Glass Leak
I know this is an old thread but it is a good one. I just ordered CRL 1303 5/16" square butyl adhesive.
http://www.filmtools.com/butyl.html
Will follow up with how it looks and works.
Old Apr 22, 2014 | 08:50 AM
Car: 1988 IROC-Z
So I am in the process of putting my deck lid back on the glass and have been searching for part number 20328200 everywhere and all places say "...discontinued part...". I noticed in the manual it states "...or equivalent...". Without nothing to compare it too I don't know what an 'equivalent' part would be? If there is anyone out there that could send a photo or part number to order it would be greatly appreciated! Thanks in advance.
-CB
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
punkmaster98
Sep 30, 2015 11:01 AM
Marc Brown
Fabrication
17
Sep 25, 2015 03:43 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
