Is it safe to drill through here?
Old Jun 24, 2004 | 09:23 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm going to be mounting a nitrous bottle here..and was wondering if it's safe to mount the brackets here...because I'll have to drill a few holes...
Old Jun 24, 2004 | 09:36 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
Just dont hit the driveshaft and i dont see why it's not a good spot. Ive seen nitrous bottles hooked up there on third gens. If you're worried about it, jack up the car and looks under it. See if anything is in the way.
Old Jun 24, 2004 | 09:38 PM
Dirtbik3r's Avatar
Then again, they might have been "flat bolt head's" on the bottom... or just a short screw.
Old Jun 24, 2004 | 10:07 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Your emergency brake cable also runs in that area. Just a thought!!!!!!!!!!
Old Jun 25, 2004 | 01:30 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
im pretty sure they fuel lines run somewhere near there too.
If it were me, i would jack up the car, pull out the driveshaft (its only 4 bolts) And then have a buddy under the car to make sure your not drilling through anything important.
Old Jun 25, 2004 | 08:20 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
...Besides all that - It looks retarted there. Yes, its easy access but for the love of all that is good - Ditch the spare tire and mount it there... No drilling thru complicated areas and you get to have the sleeper look still. Besides, if you get pulled over, less to explain.
Old Jun 25, 2004 | 09:49 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
aside of hitting the driveshaft or possibly nicking the e brake cable (things that should easily be avoided) the only thing i can think of is that you may want to double check where the wiring for your fuel pump runs(inside of the car), only because when i pulled the carpet to gut my car those wires were pretty much loose around there so i believe their location could change from car to car. Im 99.9% sure that they would not be there though, so if i were you, i would dis. the battery and just drill. And as far as fuel lines, those do not run anywhere near there under the car unless yours have been changed from their stock locations.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
86IROC112
Nov 27, 2015 09:54 AM
roysatikas
Sep 22, 2015 08:15 PM
Night rider327
Sep 16, 2015 02:20 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
