rear spoiler
Old Jul 6, 2004 | 05:38 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
rear spoiler
how do i take off the rear spoiler on my 86 camaro, there are these flat rubber pieces and i dont know how to take them off.
Old Jul 6, 2004 | 05:42 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
on my 85 there were plastic plugs in the underside of the deck that hides the bolts 10mm socket i belive. the plastic plugs just pop out with a small screwdriver.
then there should be 3 bolts in the spare well and glove box for the side ones. sometimes there is seal sealer on them that makes getting the socket on em tough just pick that stuff off first.
Jeff
Old Jul 6, 2004 | 05:47 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
thanks
thanks, now underneath will it be nasty? am i looking at paint damage? i know there might be a rust spot or two, the car has a slightly bad rust problem :/ but i got it for 600 so hey, whatever
Old Jul 6, 2004 | 05:58 PM
JeffW's Avatar
Engine: 305 tpi LB9
inside the trunk should be under your plastic interior panel.
oh and yes the paint will be junky under the spoiler.
what are you doing changing or painting?
Old Jul 7, 2004 | 12:20 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
well...
well today my friend decided to back my car out of a parking space at an apartment complex, didnt reailze it didnt have power steering and hit a pole backing up smashing the spoiler in half, i was so pissed, i took it off figured that if anything ican get a fiberglass kit and fix it but i don tknow, where is there a good place to find replacement ones?
Old Jul 7, 2004 | 01:03 AM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
junkyard if tehres one close by,
i got mine off ebay
LilHot
South Central
Apr 13, 2026 11:46 PM
colton_carlson
Mar 8, 2019 12:21 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LilHot
Aug 19, 2015 10:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
