Taking interior apart
Old Jul 8, 2004 | 06:33 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Anythign I should look out for? I have already done the seats and am about to start on the dash, side trims, and center console.
Here is what it looked like about 30 mins ago.
I found 5 bucks BTW.
Old Jul 8, 2004 | 06:44 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
save all screws and bolts in their own respective sandwich bags, labled.. that helped me a lot
Old Jul 8, 2004 | 07:08 PM
CDN_87IROC's Avatar
Since you have a digital camera ... takes pictures and docuemnt them. Will be a great reference when putting everything back in.
Old Jul 8, 2004 | 07:18 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Ahhhh thanks for the reminder.
While Im thinking about it, do the 93 and newer rear seats fold down like 92 and older?
Old Jul 8, 2004 | 07:24 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
No, newer seats have a little tab on the back that you pull to get them to fold down.
Old Jul 8, 2004 | 07:29 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Ok, so they do fold down just not the same way.
And I should say "it" folds down since it is just one big piece?
Old Jul 8, 2004 | 08:36 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
My 97 seats fold down just like my orginal ones.
Old Jul 8, 2004 | 10:48 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Just like everyone said above. Take pictures & use separate ziplock bags labeled for different screws & bolts. Take your time with everything & it will pay off when re assembly time comes around. Trust me!!!! lol!!
Old Jul 9, 2004 | 12:17 AM
Abubaca's Avatar
I agree.
LABEL THE SCREW/BOLTS!!!
Old Jul 9, 2004 | 02:47 AM
thepoz89's Avatar
Car: 89 Firebird 89 Formula one red one black
Engine: 350, 355
Be careful with the clips on the a pillars. use a small screwdriver to coax them out.
POZ
Old Jul 9, 2004 | 03:10 AM
Car: 89 RS
POZ
Damn those a pillar panels & clips!!!! lol!! On a side note, it's been a year since I put 90% of my new interior stuff in & I still have a few left over screws lol!!! You just can't win
Old Jul 9, 2004 | 11:10 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
The absolute worst part about working on the car = the door panels.
OOOOOO MG I hate them. Im going to have to buy a new drivers side one soon since it is all screwed up already (cardboarding underneath it is falling apart).
Old Jul 9, 2004 | 11:47 AM
Afroman's Avatar
Car: 1983 Black Z28
Engine: 350 5.7 Carb
Transmission: Standard
WATCH OUT FOR FAKE SCREWS!!!
those hex screws on the dash... not all over them are real.. you will strip the plastic
Old Jul 9, 2004 | 02:21 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Question on the center console - i have all the bolts to the upper layer piece unbolted (as well as the shifter ****). How do you get it to slide out with the parking brake lever in the way?
Old Jul 9, 2004 | 02:49 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
undoe the leather handle its 1 screw, phillips.
Old Jul 9, 2004 | 02:51 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Already did that. Im talking about the whole thing itself.
Old Jul 9, 2004 | 04:37 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Well after some bending action (almost breaking it) I finally got it out. Hopefully there is an easier way when it goes back in.
Old Jul 9, 2004 | 04:39 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Yea your handle should be able to go almost vertical then it will slide off you may want to lossen the cable for the install.
Old Jul 9, 2004 | 05:11 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
haha i just changed the seals and driveshaft... wish i had loosened it up before taken the car back down.
Old Jul 10, 2004 | 12:49 AM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Re: Taking interior apart
Based on that pic, RODENTS!!!
J/K.... Just did it to my car, it looked much worse!
Old Jul 10, 2004 | 01:00 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
1989-92 don't have an adjustment at the equalizer yoke. I have found an easier method to get slack in the parking brake cable. You should be able to get enough slack to pull up the handle vertical by removing the parking brake cables from the hanger brackets in the tunnel above the driveshaft. Just remember to put them back into the brackets again after.
Lon
Old Jul 10, 2004 | 12:28 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Thanks for all the help.
Any good places I should get carpet from? Id like to get something that is precut that I can just lay down and be done with it.
Should I replace the material underneath also (whatever it is called). Hopefully it comes in one whole package.
I dont think the rear carpet in the hatch needs replacing.
Old Jul 10, 2004 | 12:50 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
the stuff underneath is juke (spelling?) padding for sound cancellation/deadening whatever. if you want a super quiet inside you can put that or dynamat down. its like the padding only better quality. some people leave it out because they dont care how the inside of the car sounds and it save syou a few pounds.
Old Jul 10, 2004 | 01:53 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Oh ok cool.
Well it looks like on mine that the padding is glued to the carpet. If I can find a good store that has precut carpet with the padding then I will purchase it ASAP. Need to get this done soon.
Old Jul 10, 2004 | 06:53 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
This is who I bought my carpet and headliner from...
A1 automotive
An ACC front carpet set for $129.00!!
I don't know how they do it but they were WAY cheaper than anyone else!!
Old Jul 10, 2004 | 08:46 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
A1 automotive
What was the quality and fit like? Did it come with the dampening material underneath?
Old Jul 10, 2004 | 09:13 PM
Car: 89 RS
FYI, I've got an ACC carpet. So far I have not had any fading problems that others have had. It comes with the jute padding on the back. It's not as thick as the original padding but does its purpose. The molding was dead on too! Only a couple of things had to be done. I had to cut open the center area a little to make it fit. And I also had to trim the edges down before putting the sills down. I'm assuming that they are made this way for the different tolerances of each vehicle. (In other words, every car will fit differently so they give a little more on the edges & center.) Others complain about this, but to me, I think its a smart way to sell it. Just my opinion. Good luck!
Old Jul 10, 2004 | 09:44 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
My car was just as nasty when I took my interior apart. But after new carpet, seats, headliner and door panels it's almost like a new car. I still have to get a better center console though.
I guess that's pretty normal after so many years of use and abuse.
Old Jul 11, 2004 | 12:32 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
i hope this picture posts:
thats the ac1 carpet someone posted. it looks used to me, check out the orange crap on the drivers side. then again they say the carpet you get may or may not look like that.
Old Jul 11, 2004 | 12:37 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
thats actually the beige foot pad you see in the carpet.
Here is my 1aauto carpet, dark medium Grey
Old Jul 11, 2004 | 01:09 PM
Car: Camaro
Engine: 355c.i.
Transmission: th350
no, im talking about the coloring ot the left and right of the foot pad. it could be shadows but thats what it looks like to me
Old Jul 11, 2004 | 03:29 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
ACC has a hell of a good reputation and I know the carpet set I got from A1 was brand new.
Old Jul 11, 2004 | 05:59 PM
Car: 89 RS
Ok, these are not the greatest pics but here's my before & after with my ACC carpet. Enjoy
Old Jul 12, 2004 | 12:25 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Hehe sweeeet thanks for the pics. Makes me feel a little better.
BTW, what do I do with these nasty door panels? I can clean the carpet up, but the cardboard underneath is falling apart and coming off the upper black trim. Looks like its unrepairable.
Old Jul 12, 2004 | 12:45 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
You can make new panels out of alot of different stuff, that dark brown hard packed backing board they use for cabents are reall good to make them out of. Just go to home depot or simlar and walk around you will find something that will work.
Old Jul 12, 2004 | 12:44 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Ummmm this 1A joker company doesnt have precut carpet anymore (said that their manufacturer doesnt have them anymore).
I just bought some from http://www.salesco.com. 300 bucks precut for both passenger and rear cargo.
Old Jul 21, 2004 | 12:47 AM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Look at this nasty carpet. Looked clean when in the car. Take it out and OMG its bad. New carpet on the way.
BTW I bought new carpet from Salesco. The didnt ship it out until TODAY (10 days later). It took them more than a day to reply to my message about the order status. I believe it is because they forgot to ship and my status "reminded" them.
Needless to say I wont buy from them again (and i am about to redo the interior in my truck).
Old Jul 21, 2004 | 05:41 AM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I am in the process of redoing my interior. My biggest problem was finding all the different size torx bits in my toolbox, lol. For door panels you could do like me and make a custom set. I took the original board and added some 3-d flames and a bowtie and wrapped them in tweed to go along with my tweeded dash,console,guage cluster,sail panels...List goes on and on. All in all it took about 3 hours per door panel to remove strip cut out the 3-d forms glue them and wrap in tweed. But def. well worth it.
Old Jul 21, 2004 | 06:18 AM
gilley's86's Avatar
Car: 1986 Camaro SC
Engine: 305, AKA 30WHY
Wow, there musta been something wrong with the original carpet, you found a dog underneath. But it looks good. I still want to change my interior color over to black.
Old Jul 25, 2004 | 12:01 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I wouldnt exactly say the new carpet is "precut".
Bought from "salesco" btw.
Old Jul 25, 2004 | 12:03 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
once again, i wouldnt say it.
Old Jul 25, 2004 | 12:31 PM
  #42
jay92,85,79's Avatar
Car: 85z28,
Man that carpet does not look right.It don't even have the plastic pads on the drivers side.Do all carpets come like that? Thing about doing mine but if its like that not going to do it.
Old Jul 25, 2004 | 12:39 PM
  #43
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I would have preferred the pads as well (in fact they told me it would have them). I want new floormats anway so I dont care.
This kit was ALSO supposed to include the rear section, but it doesnt (about half of it.... besides its TWO separate pieces). So I wont be buying from this company again. mostly because they shipped it out 10 days late.
Old Jul 25, 2004 | 12:42 PM
  #44
Car: 85z28,
I think I would send that back and go with a better company.Unless u got it for real cheap. But looks like u are haveing alot of fun there.
Old Jul 25, 2004 | 01:32 PM
  #45
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
I took a lot of pics of the way it was before, so I dont think it will be too hard to trim. BUT they probably will be sending me back some cash.
Old Jul 25, 2004 | 08:01 PM
  #46
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Wow you sure thats not for a 2nd gen car? I doesn't look like it fits right. Look at my pictures on my cardomain site, my replacement was an exact match to the orginal. Had to trim for the shifter under the console but thats because they are all pre cut for manual transmissions, since the hole is smaller for those. They started and stoped in the same position as the orginals.
Old Jul 25, 2004 | 09:06 PM
  #47
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Well they did have the center console cut somewhat accurately (had to trim in front of the console under the dash so that the carpet would slide in). The rest is just beyond me. I mean it looks liek there is a foot extra of carpet on each side of the car. The rear is extended an extra 4 feet. Under the dash maybe .5 a foot.
Old Jul 25, 2004 | 11:00 PM
  #48
Car: 85z28,
Man u should send that back and go to a diff place. I mean unless u really have to get your car back on the road.It seems like they just send u a piece of carpet that they did not know what it was for.
Old Jul 27, 2004 | 04:11 PM
  #49
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Thanks, but I just started cutting on it today. Need to get it on the road quick. I cant have it sitting in the garage anylonger.
https://www.thirdgen.org/techbb2/sho...hreadid=252423
Old Jul 27, 2004 | 08:43 PM
  #50
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Salseco finally got back in touch with me. They said they sent me the carpet for a 4th gen fbody. Supposedly completely different floor designs.
